blinking problem with PIC16f887
Results 1 to 6 of 6
    The PBP default config settings for this PIC are;
    device pic16F887, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off
    So, it's actually running on the internal oscillator.
    And the PIC default setting of OSCCAL (for the internal oscillator) is for 4MHz.
    Define OSC 20 forces PBP tro assume it's running at 20MHz, but its actually running on
    the 4MHz internal osc, so Define OSC 20 screws the timing .. when it's running at 4MHz.
    For it to work as expected, at 20MHz, you would need to connect an external 20MHz
    crystal (or resonator), and change config settings to;
    device pic16F887, hs_osc, wdt_on, mclr_on, lvp_off, protect_off.
    Then use the DEFINE OSC 20.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    See Bruce,
    We need your book
    Can I get that on Amazon ?
  1. Blinking an led problem on P16F84
    By aimenbukharie in forum General
    Last Post: - 20th March 2009, 06:00
  2. PIC16F887 Config problem
    By Agent36 in forum mel PIC BASIC Pro
    Last Post: - 13th November 2008, 23:38
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. 7-segment display blinking problem?
    By serdar_ozcan in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 15:43
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
