I2CWRITE problem
Results 1 to 36 of 36
Threaded View
  1. #25
    Paul, Yes I understand that the base element number starts at 0 but, you are DECLARING only 31 elements in the array and not 32. Your declaration of the array size has to be the actual number of elements NOT the last element index. RTFM..... Also think about this statement from the manual...(While a single I2CWRITE statement may be used to write multiple bytes at once, doing so may violate the above write timing requirement for serial EEPROMs. Some serial EEPROMS let you write multiple bytes into a single page before necessitating the wait. Check the data sheet for the specific device you are using for these details. The multiple byte write feature may also be useful with I2C devices other than serial EEPROMs that don=t have to wait between writes.) Thats why I always use the page mode.....
  1. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 21:40
  2. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 20:03
  3. Problem with I2Cread and I2CWRITE function
    Last Post: - 6th June 2006, 18:32
  4. Another I2CWRITE problem
    By ErnieM in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 21:57
  5. I2CRead / I2CWrite Problem?
    Last Post: - 31st October 2005, 18:26
