I2CWRITE problem
Results 1 to 36 of 36
    Aug 2003
    Hi Gusse,
    Your code does not loop, I am sitting here wondering if there is some latency in your hardware, causing your code to run ahead of the eeprom, so the code is finished before the eeprom has finished waking up . . . Maybe in Art's too . . BTW ART, I liked your talking clock, esp when it encounters an error
    Thanks for the comments , but I don't know what you mean by the code running ahead of the EEPROM.
    The code is posted above. Writing a bunch of zeros is not exactly what I want to
    achieve, but the code exhibits the problem I'm describing.
    I suppose at some point I'll run the same code on a breadboard and try adjusting things like clock speed, pull up resistor values, and see if that helps.
    PBP should compensate for clock speed though.
    Jan 2010
    morocco
    HI art IM JUST TESTING IT ON AN OLD PIC F84A WITH 24C08 ITS WORKING WELL
    THIS MY CODE MODIFIED GUSSE CODE
    PORTB = 0
    TRISB = 0
    X       VAR BYTE
    Y       VAR BYTE
    SCL     VAR PortB.0
    SDA     VAR PortB.1
    LED     VAR PortB.3
    I2CDeviceEEprom     VAR BYTE
    I2CAddressEEprom    VAR WORD
    I2CDeviceEEprom=$A0
    X=0    'OK if EEPROM content is 00h and X = 0, if X > 0 then fails
    MAIN:
    FOR I2CAddressEEprom = 0 TO 1024
        I2CWRITE SDA, SCL, I2CDeviceEEprom, I2CAddressEEprom,[ X ], Error
        PAUSE 10
        I2CREAD SDA, SCL, I2CDeviceEEprom, I2CAddressEEprom,[ Y ], Error
        IF Y <> X THEN GOTO Error
        IF I2CAddressEEprom = 1024 AND X = Y THEN BLINK
    NEXT I2CAddressEEprom
    GOTO MAIN
    Blink:
    HIGH LED
    PAUSE 1000
    LOW LED
    PAUSE 1000
    GOTO Blink
    Error:
    HIGH LED
    PAUSE 200
    LOW LED
    PAUSE 200
    GOTO error
    YOU HAVE TO MAKE SURE ABOUT EEPROM PULLUPS AND TRIS AND PORT SET THEM TO 0 OUTPUT
    JUST LOOK TO THIS CODE TO GET SOME IDEAS OR POST UR WHOLE CODE SO EVERYONES CAN HELP .
    REGARDS
    Hi Art,
    I was thinking, in Gusse's case, the pic might blather out a bunch of commands before his eprom was awake, since he is using an OFF PIC eprom, and maybe the eprom just missed it due to the difference in boot rates. I was thinking a short pause during initialization might allow eprom to catch up . . . as I said, I was just thinking.
  1. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 21:40
  2. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 20:03
  3. Problem with I2Cread and I2CWRITE function
    Last Post: - 6th June 2006, 18:32
  4. Another I2CWRITE problem
    By ErnieM in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 21:57
  5. I2CRead / I2CWrite Problem?
    Last Post: - 31st October 2005, 18:26
