Reverse Bit Order?
Results 1 to 4 of 4
    Aug 2003
    Default Reverse Bit Order?
    Hi Guys,
    I made a cool 144 LED scroller in the last 36 hours:
    I have definitions made up for characters that appear upside down,
    so I need to reverse the order of every bit in a byte to compensate for this.
    Is there a way that's better than moving bits to a new byte ?
    At the moment that's taking 8 lines (one for each bit in the byte).
    Cheers, Art.
    Art,
    There is the REV command/operator, does that do what you want?
    Maybe this will work for you?
        BITS    VAR BYTE
        BITS = %10101010
        START:
        LCDOUT $FE,1,BIN BITS
        BITS = BITS REV 8
        LCDOUT $FE,$C0,BIN8 BITS
    echo of Henrik
    Aug 2003
    Thanks Ten words cheaper than handling the bits individually.
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Bits, Bytes Words and Arrays
    Last Post: - 14th June 2016, 08:55
  3. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  4. PICBasic newbie problem
    By ELCouz in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 01:55
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 02:07
