I'm an idiot and I don't know why! - CCP1_INT
Results 1 to 12 of 12
    Sep 2008
    Sorry Bruce, didn't see the last portion of your post. I assumed since it worked for you, it was a problem with the simulator. The simulator does show .02v when the button is not pressed and the rest of the inputs work correctly for the other interrupts. I guess I'm going to have to what for the real circuit board to arrive for further testing.
    Sep 2005
    Campbell, CA
    I don't see anthing that would pull the inputs low when the switches aren't pushed.
    Charles Linquist
    Sep 2008
    If I change the interrupt to either INT_INT or RBC_INT and move the input to another pin, it works fine. CCP1_INT does not work. It has to be the simulator. I don't have a real 16F628A to test yet. Should have the actual circuit board next week.
