RAM not reseting
Results 1 to 3 of 3
    Default RAM not reseting
    Alright I am working with USB here, I'm using a PIC18F4550 with a 20MHz HS crystal, pll etc is all running fine considering I can talk to it via USB perfectly (for the most part). My issue is that I can not get the RAM to clear old variables from before when the mC was reset. here is the gist of the code I am using:
    'Oscillator Settings:
    DEFINE  OSC 48
    DEFINE NO_CLRWDT 1
    'low portc.6                         'Not entirely sure what I made this for again....keep it for now....
    'Setup Registers:
    CMCON = 7
    ADCON1 = %00111011
    TRISA = $0f
    INCLUDE "DT_INTS-18.bas"            ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"         ; Include if using PBP interrupts
    'Includes:
    INCLUDE     "modedefs.bas"
    include     "defsvars.bas"
    INT_LIST  macro                     							 ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    INT2_INT,  _resume_sleep,   PBP,  yes
            INT_Handler    INT1_INT,  _goto_sleep,   PBP,  yes
            INT_Handler    TMR1_INT,  _Sleep_loop_timer,   PBP,  yes
        INT_CREATE                      			 	   	  		 ; Creates the interrupt processor
    '@   INT_DISABLE   INT2_INT         							 ; enable external (INT) interrupts
    '@   INT_DISABLE   INT1_INT
    @   INT_ENABLE   INT2_INT           							 ; enable external (INT) interrupts
    @   INT_ENABLE   INT1_INT
    T1CON = $31                										 ; Prescaler = 8, TMR1ON
    @   INT_ENABLE  TMR1_INT
    '@   INT_DISABLE  TMR1_INT
    'TMR1L = $01
    'TMR1H = $00
    'Main Initializations
        pause 5000
        lcdout $FE, 1, "System init"
        for index = 0 to 64             'Clear Output USB Buffer
            bufferout[index] = "0"      '*
        next                            '*
    	for index = 0 to 64				'Clear Input USB Buffer
            bufferin[index] = "0"       '*
        next                            '*
        sys_sleep_flag = 0              'Reset flag
        sys_reset_flag = 0              'Reset flag
        unlocked = 0
        data_mode = 0
        counter = 0
        'high BL                         'Turn on Backlight
        pause 10
        'high V_Supply                   '*
        pause 10
        high EEE_Power                  '*
        high EEE_switch                 'Turn on computer
        pause 500                      '*
        low EEE_switch                  '*
        'gosub StartEngine              '*
    '    gosub Initlcd                   'Initialize LCD
    '    gosub relaytest                '*
        gosub temp_init                 'Initialize Temperature Sensors
        'gosub SETLCDBG                 '*
    '    gosub starting_usb              '*
        goto usbstart                   'Initialize USB and run routines
      stop
    goto_sleep:                         'Sleep Interrupt
        sys_int_counter = 0             '*
        sys_sleep_flag = 1              '*
        sys_reset_flag = 0
    @ INT_RETURN
    resume_sleep:                       'Resume Interrupt
    LCDOUT $FE, $1, "RESET 1"
    if sys_reset_flag = 0 then
        if ENGINE_STAT = 0 then
    	    sys_reset_flag = 1              '*
    	    sys_sleep_flag = 0
    @ INT_RETURN
    if sys_reset_flag = 1 then
    '@   INT_ENABLE  TMR1_INT
        sys_sleep_flag = 0
        UCON.3 = 1                      '*
        LCDOUT $FE, $1, $fe, $c0, "RESET 2"
    @   reset
    @ INT_RETURN
    Sleep_loop_timer:
        counter = counter + 1
        if ENGINE_STAT = 1 then
            high portb.7
    	    sys_sleep_flag = 0
            low portb.7
        if sys_sleep_flag = 1 then
            low portb.7
    		    bufferout(0) = $07
    	    	bufferout(1) = $01
    	    	if counter < 30 then
    	        USBOut 1, bufferout, 64, sleep_loop_timer
                sys_int_counter = 1
                UCON.3 = 0
                'gosub entering_sleep
                low V_Supply
                low EEE_Power
                low BL
                sys_reset_flag = 0
                unlocked = 0
    	        LCDOUT $FE, $1, "Sleep"
    @           sleep
                'goto waiting_loop
            high portb.7
               	sys_sleep_flag = 0
    			sys_reset_flag = 0
    @ INT_RETURN
    'include     "fontruntime.bas"
    'Include     "lcdstring.bas"
    'include     "LCDRoutines.bas"
    include     "RelayControlRoutines.bas"
    Include	    "ja_desc.bas"
    include     "USB_Routines.bas"
    include     "I2C_Routines.bas"
    include     "ADC_Routines.bas"
    Now what it's designed to do is receive a sleep interrupt that puts the controller to sleep after attempting to send one last packet of data to the computer. After 30 tries it forces the controller to sleep, bypassing the task of sending that last packet. So now that the uC is sleeping, I hit the resume interrupt once. This wakes the controller up and it's now waiting for either another reset interrupt or another sleep interrupt. If a second reset interrupt is received the controller should then reset the whole system and start the entire program over. The problem I have is that the uC is not reseting the variables even if I try to clear them at the beginning of the program. These variables not being cleared creaates a whole world of problems when my software goes to try and talk to the PIC again. Thanks
    Also, props to Darrel Taylor for the interrupts work. It's amazing.
    What if you add
    CLEAR
    Near the beginning of your code?
    How did I miss that? thanks
  1. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 23:33
  2. On-Chip RAM
    By DaveC3 in forum mel PIC BASIC Pro
    Last Post: - 28th July 2008, 11:16
  3. Using the DS1302 scratchpad RAM ?
    By Kman in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 17:27
  4. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
  5. 18f452 tables in ram - code?
    By rshanks in forum mel PIC BASIC Pro
    Last Post: - 1st October 2004, 06:06
