Array and IF - THEN
Results 1 to 10 of 10
    LED VAR PortB.0
    Dat VAR BYTE
    Mainloop:
        DEBUGIN 1000, Mainloop, [WAIT("ABC"),Dat]
        Dat=Dat-48
        HIGH LED
        PAUSE Dat * 1000
        LOW LED
        GOTO Mainloop
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2007
    Finland
    Post
    Thanks Bruce, but what if I have several different prefixes?
    1) ABC1, ABC2, etc...
    2) DEF1, DEF2, etc...
    3) GHI1, GHI2, etc...
    4) etc...
    I cannot wait only "ABC", but basically whatever I might have in the code.
    BR,
    -Gusse-
    If you have several different prefixes, then you're stuck checking the 1st 3 bytes
    pretty much like in your original example.
    -Bruce
    tech at rentron.com
    Dec 2007
    Finland
    Post
    Thanks Bruce!
    I'll continue to use IF - THENs. This is probably something that could be placed to "PBP Wish List" if it would be benefit also someone else.
    BR,
    -Gusse-
    If you have PBP 2.60, you might do something like this ...
    LED         VAR PortB.0
    CmdIdx      VAR BYTE
    Data_Array  VAR BYTE[4]
    CmdString   VAR BYTE[3]
    ;--- Subroutine to parse commands -----------------------------
    Parse:
        FOR CmdIdx = 0 to 3
            SELECT CASE CmdIdx
              CASE 0 : ARRAYWRITE CmdString,["ABC"]
              CASE 1 : ARRAYWRITE CmdString,["DEF"]
              CASE 2 : ARRAYWRITE CmdString,["GHI"]
              CASE 3 : ARRAYWRITE CmdString,["JKL"]
            END SELECT
            ARRAYREAD  Data_Array,3,NoCmd,[WAITSTR CmdString\3]
            ON CmdIdx GOTO cmd_ABC, cmd_DEF, cmd_GHI, cmd_JKL ; found cmd
          NoCmd:
        NEXT CmdIdx
        ; if it gets here no commands were found
    cmd_ABC:
         SELECT CASE Data_Array[3]
           CASE "1"
                HIGH LED                    'If received ABC1
                PAUSE 1000                  'then turn LED on
                LOW LED                     'for 1s and return
           CASE "2"
                HIGH LED                    'If received ABC2
                PAUSE 2000                  'then turn LED on
                LOW LED                     'for 2s and return
         END SELECT
    cmd_DEF:
    cmd_GHI:
    cmd_JKL:
    Dec 2007
    Finland
    Post Great!
    Hi Darrel,
    At the moment I don't have PBP2.60, still working with 2.50c.
    I was wondering what is benefit to upgrade to 2.60, but now I see it clearly
    This parse script is something new and ARRAYREAD -function is great.
    So in Mainloop, after DEBUGIN, I should call parse? Sounds so easy!
    <code><font color="#000000">Mainloop:
        <b>DEBUGIN </b>1000, Mainloop, [<b>STR </b>Data_Array\4]
        <b>GOSUB </b>Parse
        <b>GOTO </b>Mainloop
    <b>END </b></code>
    PBP 2.60 will definitely be on my "Wish List".
    BR,
    -Gusse-
    Sep 2005
    Campbell, CA
    Darrel,
    Perfect!
    I was just in the process of writing my own routines to do the same thing.
    I was comparing element 1 in an array with every element in the second array, then element 2 in the first array against every element in the second. If I found a match, I would increment the pointers to both arrays and compare again.
    What a mess that was!
    Of course, your routine is better/faster/smaller.
    Thanks!
    Charles Linquist
