Thermo 7 segments - little problem
Results 1 to 40 of 50
    Dec 2008
    Ploiesti, ROMANIA
    Default Thermo 7 segments - little problem
    Hello !
    I intend to make one digital thermometer, this time using a 7 segments display. I use code from my previous thermometer and from this forum for interfacing PIC with display. Unfortunate on display I have only "0". I think I made some mistakes in variables statements, but I need little help....Thanks in advance for every reply.
    Jul 2008
    TURKIYE-KONYA
    if you are using isis for simulation , it is hard to scanning displays.
    it doesnt work properly when displays are scanning.
    Dec 2008
    Ploiesti, ROMANIA
    Default ?!
    Yes, I use ISIS... It's this a problem ?! I wrote another code, with the same results : "000" on display. Both (wrong) results are because of simulation ? Thanks for reply !
    Jul 2008
    TURKIYE-KONYA
    i wrote some codes below it worked on isis.
        SEGMENT_A   VAR PORTB.3
        SEGMENT_B   VAR PORTB.7
        SEGMENT_C   VAR PORTB.0
        SEGMENT_D   VAR PORTA.3
        SEGMENT_E   VAR PORTA.2
        SEGMENT_F   VAR PORTB.2
        SEGMENT_G   VAR PORTB.1
        DP          VAR PORTB.6
        BASAMAK_0   VAR PORTA.1
        BASAMAK_1   VAR PORTA.7
        BASAMAK_2   VAR PORTA.0
        BASAMAK_3   VAR PORTA.6
        DQ          VAR PORTB.5
        TEMP        VAR BYTE
        I           VAR BYTE
        SIGN        VAR BIT
        ISI             VAR WORD ; TEMPERATURE REGISTER
        COUNT_REMAIN    VAR BYTE
        MASK_0      VAR BYTE
        MASK_1      VAR BYTE
        MASK_2      VAR BYTE
        MASK_3      VAR BYTE
        CMCON   = 7
        OUTPUT      SEGMENT_A
        OUTPUT      SEGMENT_B
        OUTPUT      SEGMENT_C
        OUTPUT      SEGMENT_D
        OUTPUT      SEGMENT_E
        OUTPUT      SEGMENT_F
        OUTPUT      SEGMENT_G
        OUTPUT      DP
        OUTPUT      BASAMAK_0
        OUTPUT      BASAMAK_1
        OUTPUT      BASAMAK_2
        OUTPUT      BASAMAK_3
        SEGMENT_A   = 0
        SEGMENT_B   = 0
        SEGMENT_C   = 0
        SEGMENT_D   = 0
        SEGMENT_E   = 0
        SEGMENT_F   = 0
        SEGMENT_G   = 0
        DP          = 0
        BASAMAK_0   = 1 ; DISPLAYS 1. DIGIT
        BASAMAK_1   = 1 ; DISPLAYS 2. DIGIT
        BASAMAK_2   = 1 ; DISPLAYS 3. DIGIT
        BASAMAK_3   = 1 ; DISPLAYS 4. DIGIT
        MAIN :
            OWOUT DQ ,1,[$CC,$44]
            BEKLE :
            GOSUB EKRAN_0
            FOR I = 0 TO 4
                GOSUB TARA
            NEXT I
            OWIN  DQ ,4,[COUNT_REMAIN]
            IF COUNT_REMAIN = 0 THEN
                GOTO BEKLE
            OWOUT DQ ,1,[$CC,$BE]
            OWIN  DQ ,0,[ISI.LOWBYTE , ISI.HIGHBYTE]
            IF ISI.15 = 1 THEN
                ISI = (65535 - ISI) + 1
                SIGN = 1
                SIGN = 0
                ISI = (ISI * 10)/16
    GOTO MAIN
        EKRAN_0 :  ; TRANSFER THE REGISTERS TO DIPLAY
        MASK_3 = ISI DIG 3
        MASK_2 = ISI DIG 2
        IF SIGN = 1 THEN
            MASK_3 = " "
            MASK_2 = "-"
        MASK_1 = ISI DIG 1
        MASK_0 = ISI DIG 0
        TARA : ; SCAN THE DISPLAYS
        TEMP = MASK_3 : GOSUB TABLO
        BASAMAK_3 = 0 : PAUSE 1 : BASAMAK_3 = 1
        TEMP = MASK_2 : GOSUB TABLO
        BASAMAK_2 = 0 : PAUSE 1 : BASAMAK_2 = 1
        TEMP = MASK_1 : GOSUB TABLO
        BASAMAK_1 = 0 : DP = 1 : PAUSE 1 : BASAMAK_1 = 1 : DP = 0
        TEMP = MASK_0 : GOSUB TABLO
        BASAMAK_0 = 0 : PAUSE 1 : BASAMAK_0 = 1
        TABLO :  ; TABLE , CONVERTS THE DATAS TO 7 SEGMENT CODE
        SELECT CASE TEMP
            CASE 0
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 0
            CASE 1
            SEGMENT_A = 0
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
            CASE 2
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 0
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE 3
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE 4
            SEGMENT_A = 0
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 5
            SEGMENT_A = 1
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 6
            SEGMENT_A = 1
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 7
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
            CASE 8
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE 9
            SEGMENT_A = 1
            SEGMENT_B = 1
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 0
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE "-"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 0
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE "h"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 0
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE "o"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 0
            SEGMENT_G = 1
            CASE "b"
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 1
            SEGMENT_D = 1
            SEGMENT_E = 1
            SEGMENT_F = 1
            SEGMENT_G = 1
            CASE " "
            SEGMENT_A = 0
            SEGMENT_B = 0
            SEGMENT_C = 0
            SEGMENT_D = 0
            SEGMENT_E = 0
            SEGMENT_F = 0
            SEGMENT_G = 0
        END SELECT
    some register names and label are written in turkish. i tried to comment them to english.
    there is no transistors to drive diplays.
    if your version is same with my isis , it will work.
    all files in attachment.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You verry much for support ! ...My ISIS is Release 7.4 SP3, and Your code (copy/paste/compiling, because the zip file is empty !) DON'T WORK !!!
    Verry strange ... PIC and statements are the same ?
    Jul 2008
    TURKIYE-KONYA
    i refreshed the zip file download again.
    May 2010
    Default doesnt compile
    To mehmetOzdemir
    Hi I have downloaded and ran isis.zip files and it worked fine for me but when I compile the pic basic file in the isis.zip file and re simulate it in isis it only displays as per the attatched image.
    Any ideas? is the pic basic file ok?
    I am only learning this system so I am confused as to why it works perfect with original files but yet I cant compile it from my picbasic system.
    This is what I get when I compile the files in the zip myself.
    Jul 2008
    TURKIYE-KONYA
    I used MPASM when i compiled it. Try to use MPASM or add your config settings to the top of your code.
  1. Windows 7 64 bit problem..can anyone help???
    By ljc4141 in forum mel PIC BASIC Pro
    Last Post: - 18th July 2011, 16:29
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:55
  3. adding with 7 segments
    Last Post: - 28th November 2007, 23:51
  4. 7 segments clock
    By the_apprentice in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 19:45
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
