Problem with connection to SPI SRAM 23K256
Results 1 to 11 of 11
    It looks like you are using a LAB-X1 development board.
    Have you modified it for 3.6V?
    That SRAM isn't going to work at 5V.
    May 2009
    Yes, I am using the LAB-X1 board for this test.
    I provided a 3.3V power supply for the SRAM. But for the SI SO SCK pins I didn't modify them to 3.3V,just connect them directly to the SRAM's pins.
    I don't think the pins are 5V tolerent.
    23K256 Datasheet shows max High-level input voltage (VIH) is VCC + 0.3
    May 2009
    Thanks Darrel I will test separately and see if I could get it through
    Sounds like a good idea.
    Use a different chip. That one may not work anymore.
    May 2009
    I tested on a separate circuit with a 3.0Voltage supply using PIC16LF877A and this Ram chip. There was some results come out, but not correct....
    For example I wrote 100 into the first 100 location and the result come out to be 66 most of the time but some are 65. If I worte 0~100 accordingly in from address 0~100. The reads are some data from 0~66, it is also increasing accordingly, along with address shifting higher...it is weired..
    I was wondering whether there is some error with my codes for these setups....
    Italy
    Default Re: Problem with connection to SPI SRAM 23K256
    Hi Hankshone,
    I'm experiencing the same exact problem like yours: always reading 255
    I'm using a 23LVC1025, 5 volt SRAM memory chip with 5 volt micro. But still the same problem like yours.
    Did you found what the problem was?
    Best regards,
    Mike.
  1. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 16:42
  2. SPI communication problem (newbie)
    By lm555cn in forum Serial
    Last Post: - 3rd March 2008, 16:33
  3. USART SPI problem !
    By TripleS in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 23:09
  4. SPI Problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 14th January 2007, 09:43
  5. MicroCode Loader connection problem
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 15:54
