I got a couple of RF modules from Rentron to experiment with.
I'm using debug on the transmit side to send the data.
The problem is it will send the data to the LCD and display it momentarily then continue sending garbage to the LCD.
I know I need some kind of software filtering but I don't know where to start.
Any examples would be appreciated.
Here is what I'm sending directly to the transmitter:
debug $FE,$1
debug $FE,$80+0,"PV volts: ",$FE,$80+13,dec(PV/10),".",dec(PV//10)," "
debug $FE, $C0, "Batt volts: ",$FE,$C0+13,dec(Batt/10),".",dec(Batt//10)," "
debug $FE, $94, "Batt Curr: ",$FE,$94+13,dec(gridcurr/10),".",dec(gridcurr//10)," "
debug $FE, $D4, "Grid Curr: ",$FE,$D4+13,dec(battcurr/10),".",dec(battcurr//10)," "
On the receiving end here is how it is being received then sent to a 4x20 serial LCD:
mainloop:
Serin rcv, mode, char ' Get a char from serial input
Lcdout char ' Send char to display
Goto mainloop
Edit/Delete Message
