Calculating CRC for Modbus RTU
Results 1 to 10 of 10
    Sep 2008
    Maine, USA
    Default Calculating CRC for Modbus RTU
    Hi, I'm working on a SCADA industrial control system that communicates via Modbus RTU. I'm using a 16F648A with a MAX232 serial driver. The hardware all works fine, but I can't figure out how to calculate the CRC. Apparently Modbus has a specific CRC format, and I found a routine in another forum that claimed to work in PBpro but it isn't.
    Here's what I'm using:
    CRC=$FFFF ' initialize value
    For X = 0 to 11 ' number of bytes to process
    CRC = CRC ^ dataCRC[X] ' read through data array
    For Z = 1 to 8
    IF CRC.Bit0 = 1 Then ' check bits
    CRC = $A001 ^ (CRC >> 1)
    Else
    CRC = CRC >> 1
    EndIF
    Next Z
    Next X
    The host is sending:
    Tx:0F 03 00 00 00 04 45 27
    and my code is returning:
    Rx:0F 03 08 13 24 13 88 13 5B 00 01 38 6B
    - the last 2 bytes should be the correct CRC but my host simulator is rejecting it.
    FYI, the software Modbus host simulator I'm running is Modbus Poll from http://www.modbustools.com/
    Nice tool!
    Anyone been down this road before?
    Perth, Australia
    do you have the bytes in the correct order?
    if not, try changing it to: FOR X=11 TO 0 STEP -1
    There are only 11 bytes in the packet.
    Change it to ...
    For X = 0 to 10
    Then you should get $0FD2 for the CRC.
    Sep 2008
    Maine, USA
    Default CRC checks out but is rejected
    I changed the loop to 10 and got a CRC of 0F D2,
    but the Modbus Poll simulator still shows a CRC error.
    I am processing the bytes in the CRC calculation code in the same order that I am transmitting them - seem reasonable to me.
    According to this page ...
    http://www.lammertbies.nl/comm/info/...lculation.html
    0FD2 is the correct CRC for CRC-16 (Modbus) using [0F 03 08 13 24 13 88 13 5B 00 01].
    enterd as hex.
    Could the simulator be using a different CRC polynomial?
    Also,
    If I enter [0F 03 00 00 00 04] as sent from the host above, it shows 0x2745 for the CRC, which is the same thing the host sent.
    So that has to be the right algorithm.
    Sep 2008
    Maine, USA
    Default My simulator setup
    FYI - here's a screen shot of my Modbus Poll simulator screen and setup:
    Hope the image shows OK
  1. Dallas CRC8 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 8th May 2018, 18:07
  2. CRC Calculations
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 16th June 2009, 17:10
  3. Sensirion CRC
    Last Post: - 9th November 2007, 15:09
  4. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 22:01
  5. crc16 help
    By beto in forum mel PIC BASIC Pro
    Last Post: - 4th January 2006, 21:21
