Clamping a value to 16bits.
Results 1 to 2 of 2
    Default Clamping a value to 16bits.
    Sorry for the vague title.... Here's the scenario:
    I'm receiving a variable length string over serial, starting with a letter, continuing with any number of decimal digits and ending with a CR. I stuff the incomming characters into an array and increments a "pointer" as I fill it up.
    I need to take the value between the letter and the CR and put that into a variable, I use the "pointer" to determine how many characters I need to grab and then use something like:
    ArrayRead RxBuffer [SKIP 1, DEC5 myValue]   'Skip the letter, then grap 5 digits.
    No problem so far. But, since myValue is a word I need to make sure that I don't overflow it and I'm trying to come up with a solution to do that. If I receive more than 5 digits it's a done deal but if I receive 5 digits I need to know if those digits represents more than what can be stored in a word.
    Anyone got a slick way of doing it?
    Thanks!
    Nov 2008
    split your buffer into two words variables using skip, then do your test, e.g 90500 var1=905 var 2=00
    all the best
    Thanks!
  1. Combining 4 nibble to 16bits
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 11th November 2006, 21:40
