strange rs232 data displayed
Results 1 to 7 of 7
    Alabama,USA
    Default strange rs232 data displayed
    I am sending RS232 from PIC to PIC. Transmitter sends 16 characters, “ABCD….OP”. Transmitter output is verified with Tera Term on PC. Both Tx and Rx operates at 96k baud. Receiver stores characters in VAR RxData. RxData is displayed on LCD on my X1 board. On the first pass LCD displays ABABCDEFG….. On the second pass and all passes after the LCD displays OPABCDE….. for 16 characters. I have used different delays on the receiver before and after, hserin 2000,TimeOut , [str Rxdata\16]. I can’t figure out why this is happening. I’m not real sure about the use of STR modifier, can this be a problem? Comments please!
    Tx char string ABCDEFGHIJKLMNOP
    First pass Rx display ABABCDEFGHIJKLMN
    Second pass display OPABCDEFGHIJKLMN
    All fallowing pass OPABCDEFGHIJKLMN
    RxData var byte [20]
    RxData=0 ;clear RxData
    LCDOUT $FE,1,"Rcvd string: " ;display 16 bytes RxData
    LCDOUT $FE,$c0
    LCDOUT str rxdata\16
    pause 3000
    goto Main ;Loop forever
    TimeOut:
    LCDOUT $FE,1,"Fumble,try again"
    GOTO main
    What happens if you clear rxdata after you lcdout the value?
    I am thinking . . . . 20 byte array vs 16 byte data . . . maybe shifting . . . no time right now to play with this .
    Alabama,USA
    Default Reply to Joe
    Joe,
    I cleared RxData after LCDout as you suggested with no change in results. Then I tried this addition:
    LCDOUT $FE,1
    LCDOUT RxData[1],RxData[2],RxData[3],RxData[4],RxData[5], RxData[6]
    PAUSE 3000
    Results: first pass: BABCDE. second pass: PABCDE
    This is even more puzzling.
    String display after first pass OPABCDE…Byte display PABCDE
    String display screws up two bytes while byte display screws up one byte????
    With this change:
    hserin 2000,TimeOut , [wait ("A"),str Rxdata\15
    LCDOUT $FE,1
    pause 3000
    Results:
    first pass: ABCDEF “A” should not have been displayed
    second pass: CDEFGH
    third pass: ABCDEF same as first pass
    forth pass: CDEFGH same as second pass
    and continues to rotate output data through each pass
    If I Rx string then LCDout and END with only one cycle the results are the same ABABCDEF…..
    It sounds like RxData IS clearing based on changing first display byte. So it has something to do with hserin RxData “I think”. I added a delay after Tx output with no change in Rx. Still scratching my head...........
    By the way, I like your quote from the 1950's. I've passed it on to others.
    Default Hope this helps
    Hey Moutnain747
    What are your HSER defines set to ?
    What clock speeds etc , internal or external oscillator ?
    PIC's?
    Is there anything between the two PIC's ?
    Are they wired or wireless ?
    Did it all work before ?
    Did you try a lower baud rate ?
    Think this info may help other help you more :-)
    Thought this may help assuming you're running at 20 MHz
    DEFINE HSER_SPBRG 0 ' 9600 KBaud @ 20MHz, -86.98%
    Kind regards
    Dennis
    Post your whole code, RX and TX.
    Remember that arrays start at zero [0]
    Alabama,USA
    Default Reply:
    After testing at different Bauds, trying different Hser defines, I found that if I always use a short define string before my needed data all reception is exceptable. Sending a string of “SINKABCDEFG…… and receive with
    hserin 2000,TimeOut , [wait("SINK"),str Rxdata\16]
    is successful each loop without error. I’ve seen other examples like this and I’m sure it’s a good practice. I’m sending with 16F819 at 8Mhz internal driving a LT108CN RS232 shifter. Resulting in NO errors on Tera Term.
    Receive on X1 board, 16F877A at 20Mhz also with LT108CN. Wired connection from bread board w/ F819. My only question now is why this works on receive end:
    DEFINE HSER_BAUD 9600 ' Baud rate
    And this doesn’t work on receive end with my X1 board:
    Thank you guys for all your comments!
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
