OLIMEX ICD-2 in MicroCode Studio?
Results 1 to 3 of 3
    Feb 2009
    I was able to install PBP (v2.50B) in MPLAB (v8.10), but with some annoyances.
    I am using a 16F88 chip and in MicroCode Studio I modified the default configuration bits using the @ device ..... inline specifier since I was using PM.exe (not MPASM). Apparently MPLAB only uses MPASM. I tried to change to the __Config line, but get errors of overwriting the config byte. I believe this is due to the fact that MLAB automatically includes C:\PBP\16f88.inc which has the __Config statement in it. I tried copying this inc file into the local project directory and commenting out the __Config statement, but MPLAB still picks up the C:\PBP version. Maybe this is a system environmental path declaration issue, but didn't want to change that yet as it might effect other things.
    Is the only option to modify the .inc file in the C:\PBP directory? Not a great solution, unless I use the __Config in every PBP program.
    Quote Originally Posted by John_Mac View Post
    Hi John_Mac,
    You must install a semicolon at the beginning of the config line there so the compiler will see it as a comment, and yes then you must add the config line to your code every time. You can comment out only the MPASM config and leave the PM alone and use PM when you are feeling energy challanged I always install my own configs and use MPASM because to me it is easier. You may also modify the default configs to your personal needs and not have to mess with it.
  1. Microcode Studio ICD serial comms problem
    By spreader in forum Serial
    Last Post: - 13th March 2009, 07:08
  2. MpLAB icd 2 Microcode studio plus
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2009, 23:40
  3. Do you use ICD possibilities of MicroCode Studio
    By octal in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:22
  4. Problems with MicroCode Studio ICD
    By Muzza in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 03:37
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 01:29
