Sleep power consumption
Results 1 to 2 of 2
    Nereus's Avatar
    Nereus Guest
    Default Sleep power consumption
    Hi guys,
    I tried to measure the current when my PIC16F727 is in sleep mode but it turns out that the current is like 4.3 uA, which is much higher than 50nA, the one specified in the datasheet.
    Should I just use SLEEP() function or I need to add some other things?
    Thanks in advance!
    Nereus
    Dec 2007
    Finland
    Post
    Hi Nereus,
    Most probably you have electrolytic or tantalum capacitor connected to Vdd and that is causing some of the leakage current. Also PIC settings can increase current consumption.
    Ceramic capacitor have less leakage, but capacitance is more limited.
    What is you power supply and voltage?
    What equipment do you use for current measurement?
    Noisy environment can easily cause inaccuracy in nA range.
    BR,
    -Gusse-
  1. High Power Consumption in Sleep Mode
    Last Post: - 18th September 2014, 14:29
  2. Replies: 4
    Last Post: - 9th October 2009, 09:01
  3. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  4. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  5. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
