Problems with LCD in pic 18f8520
Results 1 to 14 of 14
    Jan 2012
    Default Problems with LCD in pic 18f8520
    Hello! I have been trying to run the LCD example that comes with de Microcode studio, but is not working!
    I'm use the BIGPIC5 that uses pic 18f8520 and i use basic lenguaje.
    This is the code that i try to run:
    DEFINE LCD_DREG PORTB
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    Pause 500 ' Wait for LCD to startup
    mainloop: Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 5000 ' Wait .5 second
    Lcdout "World"
    Pause 500 ' Wait .5 second
    Goto mainloop ' Do it forever
    The only thing that i get is some leds blinking, but in the lcd not appear anything.
    Please could you help me?
    Apr 2007
    Pennsylvania, USA
    Default Re: Problems with LCD in pic 18f8520
    Quote Originally Posted by JAVEHE View Post
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    Lcdout $fe, "Hello" ' Display Hello
    Pause 5000 ' Wait .5 second this is actually 5 seconds
    Lcdout $fe, "World"
    Make sure you have a 10K potentiometer set up so you can change the voltage on the VL pin to adjust the contrast. Not the change above in your code, whenever you use the lcdout command you need the $fe as shown in red above.
    Shawn
    Jan 2012
    Thanks 4 your answer. I did that but still not working, my lcd doesnt show anything...I see the lcd turn on and i can change the contrast but doesnt appear anything Also I see some leds blinking.
    I've been thinking if the problems is something with the lcd connector, because i've been trying everything but nothing.....How can i check that?
    Apr 2007
    Pennsylvania, USA
    You have it configured for 8bit, do you have all 8 data lines connected to the pic? LVP disabled? Extended instructions disabled? I/O's set to digital?
    Try adding to your code
    adcon1=15
    cmcon=7
    Shawn
    Moved from Code Examples.
    Shawn said what I was going to regarding setting the pins to digital, however....
    I took a quick look in the BIGPIC5 manual and in the 2*16LCD section it says[quote]
    The character LCD communicates with the microcontroller via 4-bit data bus[quote]
    What's also noticable when you look in the manual is that the LCD is connected to PortD while you have your code setup as if the LCD was connected to PortA and PortB. So, I'm not surprised it doesn't work.... And, since it's on PortD you don't need to worry about the analog stuff.
    Also, make sure that MCU-card with the 18F8720 on it have a 4Mhz x-tal. If it have something else that needs to be reflected in the code or the timing will wrong.
    So, read the manual for the development board and set the code up accordingly.
    Finally, it's been a while since I used LCDOUT but I don't think the part about the $fe that Shawn wrote is 100% correct. You need $fe if the next byte you send is to be interpreted as a command by the LCD, for example LCDOUT $fe,1 to clear the screen. But when writing actual data to it you should not have the $fe in there as it will then try to interpret the first character after $fe as a command and strange things will occur. LCDOUT $fe,"Hello" will interpret the H as a command (whatever that might be) and then try to print ello.
    Jan 2012
    Ok thank for you time!!
    I change the connection of the LCD, and i put PortD, also i change the $fe thing, but nothing happend. The only change that i see is that now the portD leds are blinking.
    Apr 2007
    Pennsylvania, USA
    You are correct, I never use LCDOUT this way. I always have a command in there so I have never come across this problem. Thanks for correcting this
    Shawn
    Jan 2012
    Yes, I said that or i try to said that. This is the example that comes with Micro Code Examples as I said in my first post. Sorry for my english
    Jan 2012
    Thanks! Now is working I had problems with "LCD connections" but now i change and is fine
    another question... can i show in my lcd a "variable"? I mean a character that changes?
    myVar VAR BYTE
    For myVar = 0 to 255
      LCDOUT $FE, 1, #myVAR
      PAUSE 1000
    NEXT
