PBP, ASM and LST files
Results 1 to 6 of 6
    Default PBP, ASM and LST files
    I'm trying to find what ASM code PBP produces for a specific routine. I'm doing this for two reasons:
    1) To learn more about ASM and how PBP works and
    2) To find out which system variables and registers the routine may use. (So I can save only the needed ones during a "PBP ASM interrupt")
    For example, I compile this code:
    If PIR1.5 THEN
      RxBuffer[RxPtr] = RCREG
      If RxBuffer[RxPtr] = 13 THEN
       ReceivedCR = 1
    RxPtr = RxPtr + 1
    If RxPtr = BufferLength THEN
      RxPtr = 0
    Looking at the bottom of the generated ASM file I find this:
    AIN?BBB	RCREG, _RxBuffer, _RxPtr
    AOUT?BBB	_RxBuffer, _RxPtr, T1
    CMPNE?BCL	T1, 00Dh, L00003
    MOVE?CT	001h, _ReceivedCR
    LABEL?L	L00003
    ADD?BCB	_RxPtr, 001h, _RxPtr
    CMPNE?BCL	_RxPtr, _BufferLength, L00005
    MOVE?CB	000h, _RxPtr
    LABEL?L	L00005
    LABEL?L	L00001
    This doesn't look much like the ASM I've seen before.... ;-) But between the above ASM file and the LST file I think I've come to the conclusion that I need to save T1 and the FSR0 registers for the above PBP code to work as an "ASM interrupt" without disturbing the PBP main program. Or is it not that "simple"?
    I guess my question is: Is there a way to get a file containing only the ASM code that will actually generate the final .hex file and not all the "extra" that is in the LST file?
    Thanks!
    Yup, the ASM produced by PBP looks a little strange but that is it.
    If you take the ASM from PBP and compile it in MPLAB it will make a HEX.
    Aug 2003
    That isn't the way a Human writes an assembler program.
    To get a useful assembler source code, download ICprog for free here:
    http://www.ic-prog.com/
    Open your hex file and select "assembler" under the "View" tab.
    It only works for 16 family devices (I think) I can guarantee it works with
    16F84/A, 16F628/A, 16F876, 16F877 hex codes.
    You'll notice you can only directly look at logic operations such as IF-THEN
    statements, NEXT-FOR loops, maths operations, etc.
    If you use any functional commands such as SOUND, LCDOUT, I2CREAD, etc.
    PBP inserts the code/libs for these commands at the start of the assembler source,
    and then each PBP command calls that code.
    For example, if you use the SERIN command three times in your PBP program,
    the assembler serial code is only inserted once (a simple routine that receives one byte),
    and the program calls that routine to receive every byte (around the areas of the program
    that each SERIN command was).
    You can save memory there because PBP uses some unnecessary "transporter variables" to
    deliver values to these libraries. With some study, in assembler, you can use them directly.
    Cheers, Art.
    Dec 2007
    Finland
    Post
    After first trials with PBP I also checked ASM-file made by PBP and I was very puzzled. Then I found this old thread (asm and pbp), which explained these strange strings (list of macros).
    BR,
    -Gusse-
    Thanks guys,
    I know how the toolchain works, PBP compiles to ASM (sort of) and MPASM assembles that file creating a .hex file. I was hoping I somehow could get an ASM file containing only what will actually get assembled after all the assembler directives etc have been parsed/evaluated and the macros "called" have been replaced with the actual ASM code.
    Oh well, the routines I'm trying to figure out here are fairly simple, like in the example I posted. Between the ASM, LST and MAC files I think and hope I can figure it out.
    Darrels wonderful interrupt routines saves all the PBP system variables and in my case that just takes too much time. So, I'm trying to figure out what variables are being used by my routines so I can save those and only those.
    Disassembling the hex file won't do me much good as I then have lost all variable names etc.
    Thanks!
    Aug 2003
    That's not very imaginative. Add this to your PicBasic code and disassemble it:
    @ nop
    @ nop
    @ nop
    Variable_Name = Variable_Name
    @ nop
    @ nop
    @ nop
    and it will be easy to find in the assembler code, even if it is renamed.
    Art.
  1. PBP 2.6/MPLab 8.33 ASM "COD" error message
    By reddog24 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:09
