ArrayWrite question
Results 1 to 6 of 6
    NO, that would give compile errors.
    ARRAYREAD gets data from an array. So you can't have constants as parameters.
    ARRAYWRITE puts data in an array.
    Consider the following program ...
    TestArray  VAR BYTE[26]
    N VAR BYTE
    N = 9
        ARRAYWRITE TestArray,["ABCDEFGHIJKLMNOPQRSTUVWXYZ"]
        HSEROUT ["Before-",STR TestArray\26,13,10]
        ARRAYWRITE TestArray,[STR TestArray\N,"12345678"]
        HSEROUT ["After -",STR TestArray\26,13,10]
    The output would look like this, and the data can be moved by changing the value of N. ...
    Before-ABCDEFGHIJKLMNOPQRSTUVWXYZ
    After -ABCDEFGHI12345678RSTUVWXYZ
    If the data is always going to be placed at the same location, you can do it this way...
    StartPos   VAR TestArray[9]
        ARRAYWRITE StartPos,["12345678"]
    Resulting in the same thing ...
    <hr>ADDED:
    You can also do the fixed position data like this ...
        ARRAYWRITE TestArray(9),["12345678"]
    Unfortunately, you can not do it like this, which would be very handy...
    N VAR BYTE
    N = 9
        ARRAYWRITE TestArray(N),["12345678"]
    hth,
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 02:53
  2. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 22:02
  3. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 25th February 2007, 23:51
  4. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
