ArrayWrite question
Results 1 to 6 of 6
    Sep 2005
    Campbell, CA
    Default ArrayWrite question
    If I use the command:
    ARRAYWRITE TestArray,[SKIP N,$81,$CF,$4D....]
    Where N = $A,
    Will it start filling TestArray with $81 at location $A, and leave locations 0-9 untouched?
    Charles Linquist
    ARRAYREAD has a SKIP modifier.
    ARRAYWRITE does not.
    Maybe you could ...
    ARRAYWRITE TestArray,[STR TestArray\N,$81,$CF,$4D...]
    Which writes the first N bytes back to themselves.
    <br>
    Sep 2005
    Campbell, CA
    So, in the above example,
    ArrayRead [SKIP N,$81,$CF,4D...]
    Would give me an array with $81 in location $A, and locations 0-9 untouched?
    Charles Linquist
    NO, that would give compile errors.
    ARRAYREAD gets data from an array. So you can't have constants as parameters.
    ARRAYWRITE puts data in an array.
    Consider the following program ...
    TestArray  VAR BYTE[26]
    N VAR BYTE
    N = 9
        ARRAYWRITE TestArray,["ABCDEFGHIJKLMNOPQRSTUVWXYZ"]
        HSEROUT ["Before-",STR TestArray\26,13,10]
        ARRAYWRITE TestArray,[STR TestArray\N,"12345678"]
        HSEROUT ["After -",STR TestArray\26,13,10]
    The output would look like this, and the data can be moved by changing the value of N. ...
    Before-ABCDEFGHIJKLMNOPQRSTUVWXYZ
    After -ABCDEFGHI12345678RSTUVWXYZ
    If the data is always going to be placed at the same location, you can do it this way...
    StartPos   VAR TestArray[9]
        ARRAYWRITE StartPos,["12345678"]
    Resulting in the same thing ...
    <hr>ADDED:
    You can also do the fixed position data like this ...
        ARRAYWRITE TestArray(9),["12345678"]
    Unfortunately, you can not do it like this, which would be very handy...
    N VAR BYTE
    N = 9
        ARRAYWRITE TestArray(N),["12345678"]
    hth,
    May 2007
    Republic Serbia
    Thumbs up
    As our friend Darrel Taylor write
    Here is example :
    If you have array = "ABCDE"
    And you do next :
    A var byte[5]
    B0 var byte : B0 = 10
    ARRAYWRITE A, [DEC B0]
    You will have next :
    array = "10CDE"
    Best regards to all and special to Darrel
    Sep 2005
    Campbell, CA
    Thanks to both of you!
    Charles Linquist
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 03:53
  2. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  3. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 00:51
  4. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
