Confused by "on Interrupt"
Results 1 to 9 of 9
    OK thanks. Can anyone show me how to set up a simple interrupt as per my original post using DT Interrupts?
    Quote Originally Posted by retepsnikrep View Post
    hI retepsnikrep,
    Sorry for the delay. DT_INTS-14.bas Works excelently as is for all the 14 bit core PICs with ports defined as PortA, PortB . . . . I ran into a little snag porting it to the 12F series for GPIO on change in the port naming convention, and the fact they do not have RBC port to interrupt. I tried making appropriate changes in DT ints but got flag errors, so I took another tact which works. I added aliases in the P12F683.inc file of mpasm so as to give the compiler the belief that GPIO and PortB were the same.
    I added this to it in the area of INTCON Bits
    RBIF                         EQU     H'0000' ; ADDED FOR dt INTS
    RBIE                         EQU     H'0003' ;ADDED
    This tells the assembler to act on RBIF as the same as GPIF and RBIE as GPIE .
    I didn't have a 683 so I compiled for a 683 and loaded into a 675, it works anyway, maybe Darrel has better ideas, this is what I was able to do.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    Include "DT_INTS-14.bas"
    CMCON0 = 7             ' comparator pins configured as I/O
    ANSEL  = 0             ' all I/O as digital
    OSCCON = %01100000     ' 96 decimal
    GPIO   = %00000000
    TRISIO = %00001000     ' GPIO Input all others as Outputs
    Option_Reg = %01000000 ' Interrupt on rising edge  INTEDG bit
    IOC = %00001000     ' Enable interrupt on change gpio.3
    i var byte
    Mainloop:
    INT_LIST  macro        ; IntSource,  Label,             Type, ResetFlag?
            INT_Handler    RBC_INT,       _Do_This,   ASM,  no
        INT_CREATE                   ; Creates the interrupt processor
    @   INT_ENABLE   RBC_INT           ; enable external (INT) interrupts
    for i = 0 to 9
    GPIO.0 = 1
    gpio.0 = 0
    next i
    gpio = 0
    Goto Mainloop
    Do_This:
    ;@ INT_DISABLE  RBC_INT
    gpio.1 = 1
    INTCON.0 = 0
    ;@ INT_ENABLE  RBC_INT
    goto mainloop
    That was nice of you to do that Joe.
    I think Darrel may have fixed that in his new version of interrupts. It is v1.00. You can find it at the bottom of this page:
    http://darreltaylor.com/DT_INTS-14/intro2.html
    It says it has GPC_INT -- GPIO Int On Change , among a bunch of other additions. But I have not played much with the DT-INTS-14 ... yet.
    Thanks, I was still using ver .93, I will download the newer ver now. I am curious to see what I missed in my attempt. I got the defines and the ifdefs but couldn't figure out the flag handler.
    EDIT:
    Well Darrel's been busy ! Added GPIO and PortA interrupts too and it looks like a whole lot more. <font color=red>Thanks Darrel !,</font color>
    So using DT_INTS-14.bas ver 1.0
    GPIO   = %00000000
    i var byte
    Mainloop:
            INT_Handler    GPC_INT,       _Do_This,   ASM,  no
    @   INT_ENABLE   GPC_INT           ; enable external (INT) interrupts
    for i = 0 to 9
    GPIO.0 = 1
    gpio.0 = 0
    next i
    gpio = 0
    Goto Mainloop
    Do_This:
    gpio.1 = 1
    goto mainloop
    Do not forget to open DT_INTS and uncomment these 2 lines
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    Thanks that looks good.
  1. Confused over A/D settings
    Last Post: - 22nd February 2010, 11:44
  2. 12C671 & Osccal register - I am confused
    Last Post: - 26th December 2009, 07:03
  3. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:01
  4. Hlp - newcomer getting confused
    By chunk in forum General
    Last Post: - 23rd January 2006, 19:47
  5. Problem with "on Interrupt" and PIC18F4620
    By philtep in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 03:24
