Variable table
Results 1 to 2 of 2
Thread: Variable table
    Oct 2006
    Edmonton AB Canada
    Default Variable table
    Hi gang,
    I'm looking for a creative way of managing a variable. Creative being a minimal amount of code. I need to store the state of 5 outputs on the fly, so that the last known state can be loaded upon startup.
    With the 5 outputs, each can have 2 states (high or low). Each of the outputs can be changed independently, so the actual variable, including all high or all low, as best I can figure, has 17 possible states.
    Is it better to do an evaluation of all the ports every time an output changes, and keep a small variable, or is it better to keep 5 variables and compare them together to get a single variable to write to memory?
    Which method results in the smaller (and thus faster) code?
    Thanks for any ideas
    Gary
    Miami, Florida USA
    MY_VARIABLES VAR BIT[5]
    Would do the trick.
    2^5 = 32 posible states
    So you can get 32 possible states with 5 variables defined as bits.
    If you want to monitor the state of the I/O ports then one way to do it is
    SYMBOL VAR_0 = PORTB.0 'If you are using PORTB
    SYMBOL VAR_1 = PORTB.1
    SYMBOL VAR_2 = PORTB.2
    SYMBOL VAR_3 = PORTB.3
    SYMBOL VAR_4 = PORTB.4
    Or you can do it like this
    MY_VARIABLE VAR BYTE
    MY_VARIABLE = PORTB
    And then check the status of the bits in MY_VARIABLE
    IF MY_VARIABLE.0 = .... THEN ...
    IF MY_VARIABLE.1 = .... THEN ...
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  3. PIC 18F452 Table Pointer/ Table Read
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 03:07
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
  5. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 21:16
