16F181: can't wake up from sleep
Results 1 to 8 of 8
    Quote Originally Posted by Gusse View Post
    Some lessons learnt <u>again</u>
    That happens to you too ? Welcome to my world
    Aug 2007
    Mississauga, Ontario, Canada
    OK guys... got it going. Here is the snippet of the the code around the sleep command. Works like a charm.
    What I've done is I gave it a delay of 3 seconds from the closure of the switch to make sure PortB is undisturbed, then I took a snapshot of PortB (read it into a dummy variable), set up the interrupt and put the PIC to sleep. Once awoken, I read PortB again and cleared the flag.
    Now here is another question... I'm also running Darrel Taylor's interrupt routine based on TMR1. I use it to flash a LED if a battery is low.
    However, once the chip awakens from sleep, it would appear that this interrupt isn't working anymore (ie. no flashing).
    I've noticed the same thing happens if I try to declare INTCON=00001000 at the top of the program... does this make sense?
        pause 3000
        dummyread=PortB
        intcon=%00001000
        @ sleep
        @ nop
        dummyread=PortB
        intcon.0=0
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. wake up from sleep
    Last Post: - 31st August 2007, 17:09
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
  5. 18F2320 and sleep function
    By Brian in forum mel PIC BASIC Pro
    Last Post: - 10th March 2005, 13:11
