strange serout2 problem
Results 1 to 3 of 3
    Dec 2009
    Question strange serout2 problem
    Hi everyone, and happy new year
    I am trying a rs232 communication. I use 16f84a. I am a beginner in electronics.
    This problem seems strange:
    I use hyper terminal. I have a Max232 circuit with Sub-D 9-F. I also send the schematic of the circuit (my source is http://sodoityourself.com/max232-ser...vel-converter/ )
    Here is the problem, controller led is blinking but there is nothing on hyper terminal
        OutGoing VAR Byte
        OutGoing = "K"
        D_Forwarder VAR PORTB.3  'data forwarder
        Forwarder VAR PORTA.1  ' Controller led
     PAUSE 500
            SEROUT2 D_Forwarder,396,["O",OutGoing ] '2400 baud rate
            HIGH Forwarder
            PAUSE 100
            LOW Forwarder
    But in this code, while the led is blinking i also see both of the O and K characters, it works.
        OutGoing1 VAR Byte
        OutGoing1 = "K"
        OutGoing2 VAR Byte
        OutGoing2 = "S"
        D_Receiver PORTB.2       'data receiver
        Receiver VAR  PORTA.0   ' Controller led
     PAUSE 500
            SEROUT2 D_Forwarder,396,["O",OutGoing1 ] '2400 baud rate
            HIGH Forwarder
            PAUSE 100
            LOW Forwarder
            SEROUT2 D_Receiver ,396,["O",OutGoing2 ]
            HIGH Receiver
            PAUSE 100
            LOW Receiver
    Is this correct?
    This line in the program you say works should cause the program to not compile.
    You forgot the VAR.
    Dec 2009
    I erased it accidently, sorry There is a VAR over there, it compiles.
  1. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 15:26
  2. PIC stop responding - Strange Problem!
    Last Post: - 31st August 2009, 15:06
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  4. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 14:47
  5. Advantages of HSerout over Serout2 and a problem
    By rpstroj in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 23:19
