Recording incoming logic signal duration, both edges - how to?
Results 1 to 7 of 7
Threaded View
  1. #4
    SWITZERLAND (french speaking)
    Hi Dave,
    I'm recording all kind of remotes like ones for TVs as well as garage-door openers, electric-shades and so on. My remote is ment to be really "universal", well at least I dream it will be so.
    As where most TV protocols work fine with my code, the other ones don't use "standard" protocols and that's the reason why I have to record both signal's state durations with, appearently, a little more precision.
    This is the "learning sequence" of the code I currently work on:
    <html><head></head><body><!--StartFragment--><pre><code><font color="#000000">LEARN:
    <b>PULSIN </b>IRM_Out, 0, l_Bit[0]        <font color="#000080"><i>'get the first Low pulse
    </i></font><b>TOGGLE </b>C_Led                       <font color="#000080"><i>'indicate the &quot;waiting state&quot; to user
    </i></font><b>IF </b>l_Bit[0] = 0 <b>THEN </b>LEARN:        <font color="#000080"><i>'wait for the first pulse to start recording
    </i></font>C_Led = 1                          <font color="#000080"><i>'led is ON, learn has started
    </i></font><b>RCTIME </b>IRM_Out, 1, h_Bit[0]        <font color="#000080"><i>'get first High pulse from IR Module
    </i></font><b>FOR </b>Ctr_A = 1 <b>TO </b>(Max_Bit - 1)
       <b>RCTIME </b>IRM_Out, 0, l_Bit[Ctr_A] <font color="#000080"><i>'get Low pulse (1 to 38) from IR Module
       </i></font><b>RCTIME </b>IRM_Out, 1, h_Bit[Ctr_A] <font color="#000080"><i>'get High pulse (1 to 38) from IR Module
    </i></font><b>NEXT </b>Ctr_A
    <b>RCTIME </b>IRM_Out, 0, l_bit[Max_Bit]  <font color="#000080"><i>'get last Low pulse from IR Module
    </i></font><b>RCTIME </b>IRM_Out, 1, H_bit[Max_Bit]  <font color="#000080"><i>'get last High pulse from IR Module
    </i></font>C_Led = 0
    <b>END</b></code></pre><!--EndFragment--></body></html>
    Full code is in attached ZIP file.
    I'll try to adapt your code to my usage and see what I get. Thanks a lot for that.
    Bruce,
    I have only some 10F, 12F and 16F in my drawer
    Nevertheless, I'm going to grab the datasheet of this particular PIC and see what this function does. Something new to learn
    Roger
  1. Replies: 24
    Last Post: - 1st December 2009, 09:01
  2. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 17:28
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
