Slow code needs a tune up
Results 1 to 8 of 8
    I am using an ignition simulator that is activating a racing ignition system. In essence the simulator triggers the points input on the ignition system. I am reading the tach output into an opto-isolator.
    http://msdignition.com/Products/Igni...n_Control.aspx
    http://msdignition.com/product.aspx?id=4777&terms=8998
    Tobias,
    To me the two versions in your first post looks identical, am I wrong?
    Yea I screwed that up here is the timer code
    DEFINE OSC 20
    Prefix          con      $FE             ' needed before each command
    LcdCls          CON      $51             ' clear LCD (use PAUSE 5 after)
    CursorPS        con      $45             'Cursor Position
    Capture         VAR     PIR1.2		      ' CCP1 capture flag
    Overflow        VAR     PIR1.0	    	' Timer1 overflow flag
    RPM             var     word
    period          var     Word
    LCD             VAR     PortC.6    'LCD output
    Gate1           Var     PortC.1
    Gate2           var     PortD.1
    Gate3           var     PortD.2
    Gate4           var     PortD.3
    Gate5           var     PortD.6
    Gate6           var     PortD.7
    Gate7           var     PortD.5
    Gate8           var     PortD.4
    ADCON0 =0
    ADCON1.3=1
    ADCON1.2=1
    ADCON1.1=1
    ADCON1.0=1
    TRISE.0=1
    TRISE.1=1
    CCP1CON = %00000110   			' Enable the CCP1 capture, every 4th rising edge
    SEROUT2 LCD,84, [Prefix, LcdCls]
    low Gate1
    Low Gate2
    Low Gate3
    Low Gate4
    Low Gate5
    Low Gate6
    Low Gate7
    Low Gate8
    loop:
    T1CON = %00100000 ' TMR1 prescale=1:2 Timer OFF
    '11 = 1:8 prescale value
    '10 = 1:4 prescale value
    '01 = 1:2 prescale value   '''
    '00 = 1:1 prescale value
    TMR1H = 0                               ' Zero the Timer
    TMR1L = 0
    capture = 0
    Start:
    	IF capture = 0 Then
    	  'SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM ",#0, " ", #Period]
        goto Start	' Wait here for the first capture
     T1CON.0 = 1             ' Start the Timer
     capture = 0             ' Reset  the capture flag
    CaptureLoop:
    	IF capture = 0 Then
        goto CaptureLoop	' Wait here until captured
    period.lowbyte = CCPR1L		' Store the captured value in
    period.highbyte = CCPR1H	' period variable
    'period = period / 2
    RPM = 10000
    RPM = RPM * RPM ' 100,000,000
    RPM = DIV32 period ' 100,000,000 / RevCount
    RPM = RPM * 60 ' Per minute
    RPM = DIV32 400
    RPM = (RPM*5)
    'SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM ",dec5 RPM, " ", #Period]
    gosub cleartimer1
    GoTo loop					' Do it forever
    ClearTimer1:
    IF (capture = 0) Then
      goto cleartimer1	' Wait for beginning of next period
    TMR1L = 0					    ' Clear Timer1 low register
    TMR1H = 0					    ' Clear Timer1 high register
    capture = 0					    ' Clear capture flag
    overflow = 0				    ' Clear overflow flagReturn
    Talking method problem ...
    One good reason could be the 2 DIV32 INSIDE the test loop ...
    I measured once DIV32 took ~ 700µs ...
    this is at least one very good reason for the PULSIN way to show a false result on the scope ... despite calculated RPM value to be right.
    Question
    With some little reflexion ....
    I'd ask you to scope the signal you use from your gadget ...
    Is it really a nice symmetrical square wave ???
    Its not a perfect function generator type square wave for sure. My scope has a USB output on it. This will be a good reason to learn how to send screen shots to my laptop. I will work on that tonite.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Code Executing Slow
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 5th September 2008, 22:09
  5. Making Program Code Space your playground...
