Slow code needs a tune up
Results 1 to 8 of 8
    Default Slow code needs a tune up
    16F877A measuring RPM. I have the timer style and PULSIN versions working fine. However my timer style of code is very slow. I toggle an output and on the scope I get 14 hz at 5000 rpm (4 counts/rev) when using the timer code. When I use the Pulsin I get 55 hz. Any ideas why its slower? I was under the impression the timer version would be alot faster than the Pulsin.
    DEFINE OSC 20
    RPM             var     word
    Period          var     Word
    HRPM            var     word
    LRPM            var     word
    RPM_Total       VAR     Word
    LCD             VAR     PortC.6    'LCD output
    RPMInput        var     PortC.2
    Gate1           Var     PortC.1
    Prefix          con      $FE             ' needed before each command
    LcdCls          CON      $51             ' clear LCD (use PAUSE 5 after)
    CursorPS        con      $45             'Cursor Position
    SEROUT2 LCD,84, [Prefix, LcdCls]
    Include "modedefs.bas"	' Mode definitions for Serout
    Low Gate1
    OPTION_REG.7 = 0 'Pull Ups enabled
    INTCON.7=0
    ADCON0.0 =0
    ADCON1 =7
    Loop:
    If RPMInput = 0 then
      Pulsin RPMInput, 0, LRPM
      PULSIN RPMInput, 1, HRPM
      RPM_Total = HRPM + LRPM
      RPM = 1000
      RPM = RPM * RPM
      RPM = DIV32 RPM_Total   ' 1,000,000 / Pulse_Total
      RPM = RPM * 60            ' Per minute
      RPM = Div32 8            ' 4 pulses per rev
    toggle  gate1
    goto loop
    DEFINE OSC 20
    RPM             var     word
    Period          var     Word
    HRPM            var     word
    LRPM            var     word
    RPM_Total       VAR     Word
    Gate1           Var     PortC.1
    Low Gate1
    INTCON.7=0
    ADCON0.0 =0
    ADCON1 =7
    Loop:
      RPM = 1000
      RPM = RPM * RPM
    toggle  gate1
    goto loop
    Wink
    Just curious to know what you use as a sensor ...
    I am using an ignition simulator that is activating a racing ignition system. In essence the simulator triggers the points input on the ignition system. I am reading the tach output into an opto-isolator.
    http://msdignition.com/Products/Igni...n_Control.aspx
    http://msdignition.com/product.aspx?id=4777&terms=8998
    Tobias,
    To me the two versions in your first post looks identical, am I wrong?
    Yea I screwed that up here is the timer code
    DEFINE OSC 20
    Capture         VAR     PIR1.2		      ' CCP1 capture flag
    Overflow        VAR     PIR1.0	    	' Timer1 overflow flag
    RPM             var     word
    period          var     Word
    Gate1           Var     PortC.1
    Gate2           var     PortD.1
    Gate3           var     PortD.2
    Gate4           var     PortD.3
    Gate5           var     PortD.6
    Gate6           var     PortD.7
    Gate7           var     PortD.5
    Gate8           var     PortD.4
    ADCON0 =0
    ADCON1.3=1
    ADCON1.2=1
    ADCON1.1=1
    ADCON1.0=1
    TRISE.0=1
    TRISE.1=1
    CCP1CON = %00000110   			' Enable the CCP1 capture, every 4th rising edge
    low Gate1
    Low Gate2
    Low Gate3
    Low Gate4
    Low Gate5
    Low Gate6
    Low Gate7
    Low Gate8
    loop:
    T1CON = %00100000 ' TMR1 prescale=1:2 Timer OFF
    '11 = 1:8 prescale value
    '10 = 1:4 prescale value
    '01 = 1:2 prescale value   '''
    '00 = 1:1 prescale value
    TMR1H = 0                               ' Zero the Timer
    TMR1L = 0
    capture = 0
    Start:
    	IF capture = 0 Then
    	  'SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM ",#0, " ", #Period]
        goto Start	' Wait here for the first capture
     T1CON.0 = 1             ' Start the Timer
     capture = 0             ' Reset  the capture flag
    CaptureLoop:
    	IF capture = 0 Then
        goto CaptureLoop	' Wait here until captured
    period.lowbyte = CCPR1L		' Store the captured value in
    period.highbyte = CCPR1H	' period variable
    'period = period / 2
    RPM = 10000
    RPM = RPM * RPM ' 100,000,000
    RPM = DIV32 period ' 100,000,000 / RevCount
    RPM = DIV32 400
    RPM = (RPM*5)
    'SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM ",dec5 RPM, " ", #Period]
    gosub cleartimer1
    GoTo loop					' Do it forever
    ClearTimer1:
    IF (capture = 0) Then
      goto cleartimer1	' Wait for beginning of next period
    TMR1L = 0					    ' Clear Timer1 low register
    TMR1H = 0					    ' Clear Timer1 high register
    capture = 0					    ' Clear capture flag
    overflow = 0				    ' Clear overflow flagReturn
    Talking method problem ...
    One good reason could be the 2 DIV32 INSIDE the test loop ...
    I measured once DIV32 took ~ 700µs ...
    this is at least one very good reason for the PULSIN way to show a false result on the scope ... despite calculated RPM value to be right.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. Code Executing Slow
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 5th September 2008, 21:09
  5. Making Program Code Space your playground...
