Help with code please
Results 1 to 2 of 2
    Hi Tina10, welcome to the forum.
    Here, totally untested, try this:
    define  NO_CLRWDT  1
    define  OSC        4       ' OSCCON defaults to 4MHz on reset
    Include "modedefs.bas"
    @ __CONFIG _IntRC_OSC & _WDT_OFF &_MCLRE_OFF & _CP_OFF
    trisio = %00011111
    MyVar var byte
    index var byte
    mainloop:
    ' alias ports to a variable
    myvar = gpio
    MyVar.0 = gpio.0
    MyVar.1 = gpio.1
    Myvar.2 = gpio.2
    MyVar.3 = gpio.3
    MyVar.4 = 0 ' zero the upper 1/2 byte
    MyVar.5 = 0
    MyVar.6 = 0
    MyVar.7 = 0
    'convert binary port value to ascii representation of the numbers
    lookup myvar,["0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15"]index
    'send out port 5 serially
    Serout gpio.5,T2400,[254,128,index]
    goto mainloop
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
