Help with code please
Results 1 to 2 of 2
    Jan 2010
    Question Help with code please
    Hi, I am new to the field of PIC programming but trying to catch up. I need some help guys to write my code.
    I have bought 12F508 and pins GP0 to 4 are pulled high by 10K with pushbuttons attached to the ground. I would like to have an shortest possible code to read the ports and send an serial command through GPIO.5 based on combinations of the buttons pressed. I have tried other ways using AND's but the PIC runs out of memory with this kind of approach.
    I tried with the following but it's not working. I would like to know if the problem is with the code or my hardware. Once I make sure the code is ok then I will jump on to check the hardware settings.
    define  NO_CLRWDT  1
    define  OSC        4       ' OSCCON defaults to 4MHz on reset
    Include "modedefs.bas"
    @ __CONFIG _IntRC_OSC & _WDT_OFF &_MCLRE_OFF & _CP_ON
    Tx  	    var     GPIO.5
    i			var		byte
    pause 50
            ' Initialize the processor
            TRISIO = %011111        ' 1 bits are inputs - O are outputs
            Tx=0			        ' Put Tx pin low
            OSCCAL = 0
    PAUSE 50
    start:
    while 1
    i=gpio
    if i=%11110 then      ' if gpio.0 is pressed
    'Serout............few bytes
    if i=%01110 then      ' if gpio.0 + gpio.4 is pressed
    wend
    I am little confused as to when I write i=gpio, does it stores i[0]=gpio.0 OR i[7]=gpio.0
    Are the if statements above correct, I mean what will the PIC do with remaining 3 bits in i variable
    Please help me understand how this will work. Thanks
    Hi Tina10, welcome to the forum.
    Here, totally untested, try this:
    define  NO_CLRWDT  1
    @ __CONFIG _IntRC_OSC & _WDT_OFF &_MCLRE_OFF & _CP_OFF
    trisio = %00011111
    MyVar var byte
    index var byte
    mainloop:
    ' alias ports to a variable
    myvar = gpio
    MyVar.0 = gpio.0
    MyVar.1 = gpio.1
    Myvar.2 = gpio.2
    MyVar.3 = gpio.3
    MyVar.4 = 0 ' zero the upper 1/2 byte
    MyVar.5 = 0
    MyVar.6 = 0
    MyVar.7 = 0
    'convert binary port value to ascii representation of the numbers
    lookup myvar,["0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15"]index
    'send out port 5 serially
    Serout gpio.5,T2400,[254,128,index]
    goto mainloop
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
