I made the same transition a couple of years back.
PBP 2.47 supports the 18F4620 but has some bank switching issues that may affect you. PBP 2.60+ is worth the upgrade because you get signed LONGs which are very handy for high precision arithmetic and saves a lot of checking to make sure a PIC16F877 results never goes negative.
You will need to open the MPASM file P18F4620.inc and search for the first occurrence of the word DEBUG. Comment this out by placing
in the first column followed by a space. Otherwise the PBP reserved word DEBUG gets confused with the MPASM reserved word DEBUG and everything falls apart.
HTH
BrianT
