PicBasic SERIN
Results 1 to 2 of 2
Thread: PicBasic SERIN
    Dec 2009
    Default PicBasic SERIN
    Hello!
    How to turn on LED with PIC16F84A when I send some date from computer
    So, how to use the command SERIN?
    Thanks!
    Hello Azra01,
    UnTested Sample:
    PortA = %00000000 'all outputs low
    PortB = %00000000 'all outputs low
    TrisA = %00000000 'All as outputs
    TrisB = %00000001 ' B.0 as input all others as outs
    include"modedefs.bas" ' includes aliases for modes
    b0    var byte
    dummy var byte
    mainloop:
    'from the manual except I named the port to be used <> 1
    serin PortB.0, n2400,["A"],B0 'waits for ASCII A then saves next data
    ' not exactly from the manual but close
    branch B0, [dog, cat, fish, mainloop] 'same as if then spaghetti
    dog: 'here is where the work gets done, in the subs
    porta.0 = 1
    goto mainloop
    cat:  'here is where the work gets done, in the subs
    porta.0 = 0
    goto mainloop
    fish:   'here is where the work gets done, in the subs
    for dummy = 0 to 9
    portb.1=1
    portb.1 = 0
    next dummy
    goto mainloop
    So send out an ASCII "A" and the number 1 and it jumps to DOG
    A and 2 ,and it jumps to CAT . . .
    EDIT: just checked it, compiles . . . should run . . .
  1. Serin picbasic
    By azra01 in forum General
    Last Post: - 18th December 2009, 23:38
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  4. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
  5. PicBasic Fundamentals
    By Billyc in forum General
    Last Post: - 4th May 2004, 11:04
