Interruption
Results 1 to 15 of 15
Thread: Interruption
    Dec 2009
    Default Interruption
    Hello everyone, again!
    This time I'm wondering if there is any way to have an event(like a button press) interrupt the code and go to a line label at any time?
    The problem with my code is that the controller only checks for the button press after that pause. That pretty much means that you have to hold down the button to get the right timing in order for the moving LEDs to switch direction(which is what my code is about). So is there any way to interrupt the program at ANY time and then point it at a line label to continue there?
    this is my code:
    x var byte
    switch var bit
    TRISA = 1
    TRISC = 0
    switch = 1
    mainloop:
    x = 1
    loop:
    PORTC = x
    if switch = 1 then
    	if PORTA.3 = 0 then
    		switch = ~switch
    		goto loop
    	if x == 8 then
    		goto mainloop
    		x = x << 1
    		goto loop
    	if PORTA.3 = 0 then
    		switch = ~switch
    		goto loop
    	if x == 1 then
    		x = 8
    		goto loop
    		x = x >> 1
    		goto loop
    Look at interrupt on change normally on PORTB.
    Dec 2009
    We'll I've got a premade board - The PICKit 2 so the button is on the PORTA.3 pin - just like in the program. Is there no way to do it with that pin?
    Check the data sheet and see what that pin can do. If it has ADC then with some imagination you could do an ADC interrupt.
    But just change things around to use an interrupt pin. That is what they are for.
    Talking
    My crystal ball says ...
    " Pickit2 with a ready made demo card means a 16F690 " ...
    RA.3 shows an Interrupt on change feature ...
    soooo ... just use it !!!
    PS: try to give SOME MORE INFOS if you have further questions ...
    Aug 2003
    An interrupt is overkill for this, and not the typical way to handle the problem at all.
    I'd use a counter to have your button checked every 10ms, and LED routine run every 500ms like this.
    and you get to save the interrupt for when it's actually needed.
    x var byte
    direction var bit
    timerbyte var byte
    TRISA = 1
    TRISC = 0
    x = 1
    loop:
    PORTC = x
    pause 10
    timerbyte = timerbyte + 1
    IF PORTA.3 = 0 then
    IF direction = 0 THEN
    direction = 1
    direction = 0
    ENDIF ' direction
    ENDIF ' button
    IF timerbyte = 50 THEN timerbyte = 0 ' 500ms has passed if timerbyte = 0
    IF timerbyte = 0 THEN
    	IF x = 8 THEN x = 1
    	x = x << 1
    	IF x = 1 THEN x = 8
    	x = x >> 1
    ENDIF ' direction
    ENDIF ' timerbyte
    goto loop
