Proportional fan control. I suck at math!
Results 1 to 12 of 12
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by polymer52 View Post
    I need the fan to come on at 90 deg and output a PWM signal of 50% at that temp. Then increase the duty cycle of that PWM signal as temperature (voltage) increases to a maximum of 100% at 120deg and above.
    So basically, assuming the PWM part has 255 steps, when temp = 90 the PW would = 0, and when its 120 the PW = 255 ?
    So that's a 30 degree range represented by a 255 step. 255 / 30 = 8.5
    That would mean that for every degree the PW is 8.5
    You would then need to write your code so that if temp < 90 PW=0 and if temp >120 then PW =255 to give you your range. I would then use a variable to give you the 30 degree steps you need, something like range value = temp - 90, and then use this for the steps, sorta PW= range value X 8.5
    This may not be the ideal way, and I'm sure it could be simplified, but it's the way I would approach the problem. You need to choose a PIC and set the resolution of the PWM you wish to use, the more steps the smoother the fan control will be
    EDIT:
    just re-read your post, you want the fan to run at 50% at 90 degrees, if so then wouldn't that be a simple case of a statement like
    If temp >90 and <120 then PW=127
    If temp > 120 then PW=255
    Hope this helps
    Feb 2005
    brookfield, ct, usa
    Hi Polymer
    try this - I used a 12F683
    Take care
    Alec
    '* Name : fan controller_forum *
    '* Author : Alec Noble *
    '* Notice : Copyright (c) 2010 Alec Noble *
    '* : All Rights Reserved *
    '* Date :1/3/2010 *
    '* Version : 1.0 *
    '* Notes : *
    @DEVICE=PIC12F683
    define OSC 8
    OSCCON = %01110001 ' Internal 8MHz osc
    CMCON0 = 7 ' Comparators off
    WPU = 0 ' Internal pull-ups = off
    'GPIO = %00000000 ' All outputs = 0 on boot
    TRISIO = %000000001 ' GPIO.0=data in, GPIO.2=PWMout, GPIO,1,3,4,5 unused
    '******************** set up ADC ************************************
    ANSEL = %00010001 'gpio.0 analog, others digital, ADC clock fosc/8
    DEFINE ADC_BITS 10 ' ADCIN resolution (Bits)
    DEFINE ADC_CLOCK 1 ' ADC clock source (Fosc/8)
    DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
    adcon0.7 = 1
    '********************* define variables *******************************
    sensor var word
    temp var word
    span var byte
    duty var word
    '********************** intitialize variables *************************
    duty = 0
    temp = 0
    span = 0
    '********************** Program starts here **************************
    HPWM 1, duty, 5000 'set PWM output
    adcin 0, sensor 'read temperature sensor
    sensor = sensor * 500
    temp = div32 1023 'convert ADC to degrees
    span = temp - 90 'get range above 90 degrees
    if temp < 90 then 'less than 90 degrees PWM off
    duty = 0
    if temp > 90 and temp < 120 then
    duty = 130 + (span * 4) 'between 90 and 120 start with 50% and linearly
    endif 'raise rate up to 120 degrees
    if temp > 120 then 'above 120 degrees 100%
    duty = 255
    pause 100 'pause to avoind to frequent cycling
    goto main 'do it again
    California, USA
    I think Malcolm had it... it's about 8.5 PWM steps per degree, over a 30 degree span.
    So, something like this?
    If temp < 90 then
    	duty = 0
    	duty = (temp - 90)  * 85 /10   'subtract 90 from temp, and multiply * 8.5
    steve
    Nov 2009
    Wagoner, USA
    Quote Originally Posted by malc-c View Post
    EDIT:
    Hope this helps
    I think I have settled on the 12F683. It has an 8mhz internal osc, A/D converter and hardware PWM so it doesn't have to be constantly strobed.
    Also the 2k words program memory is a nice touch. I can be as sloppy with my code as I want and still have room to spare.
    Getting closer..Anything below 90deg fan is off so:
    If Temp<90 then HPWM=0
    Then at 90 deg fan comes on at 50%:
    If Temp=90 then HPWM=127 (50% of 255 leaving 127 remainder). 'Minimum fan speed
    Here is the part I don't understand. From 91 to 120 the fan speed needs to vary according to temperature so:
    From 91 to 120 each degree needs to widen the HPWM by 4.23 (remaining 127 / 30 deg) speeding up the fan incrementally by temp.
    Finally
    IF Temp>= 120 then HPWM=255 'Full fan speed at or above 120 deg
    The actual PBP command is: HPWM Channel,Dutycycle,Frequency
    so at 90 deg on channel 1, 50% duty cycle and 1khz rate the command
    would be HPWM 1,127,1000. I can replace the 127 with a variable.
    I f you are asking then yes. You can use a variable.
    California, USA
    Ahh, that's right, the minimum on speed is 50%... (duty = 128)
    So then you've got to increase duty by about 4.2 for every degree between 90 and 120 ...
    How about something along these lines:
    If temp < 90 then duty = 0
    If temp > 120 then duty = 255
    If temp > 89 AND temp < 120 then duty = 128 + ((temp - 90) * 42 / 10)
    steve
    Nov 2009
    Wagoner, USA
    Perfect!
    I knew you guys were brainie.
    I'll buy you a virtual beer.. Cheers!
    malc-c's Avatar
    malc-c Guest
    Nice one Steve !
    Good teamwork
    Nov 2009
    Wagoner, USA
    And thanks to alec also. Somehow I missed his post earlier but he did a lot of the work for me and between Steve and Alec I think we've got it..
    I have a solar hot air furnace which I'm building this control for. It is just a relay controlled fan right now which, early in the morning, kicks on at 110 degrees then cools the collector down too much and shuts off at 90 deg then cycles again. It also outputs data to a serial LCD module such as ambient temp, collector temp, fan relay on/off and vent servo position.
    With the proportional control I can have it to come on at 90 degrees and only move the amount of air that it can heat without shutting off and cycling increasing the heating time.
    As the sun rises and it gets hotter in the collector the fan can move ever increasing amounts of air until it gets to full speed. Full collector temperature ranges from 90 at cut in to around 140-170 deg at noon depending on outside temperature.
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 15:40
  2. Transistor selection, PWM fan control
    By 124C41 in forum Schematics
    Last Post: - 22nd December 2008, 15:33
  3. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
  4. Replies: 9
    Last Post: - 30th August 2005, 06:33
