Proportional fan control. I suck at math!
Results 1 to 12 of 12
    Nov 2009
    Wagoner, USA
    Default Proportional fan control. I suck at math!
    I have a solar collector controller and I need to build a proportional fan controller for it and I need some help with the math. I need it to be proportional from 90 to 120 deg F and off below 90 deg.
    I'm using an LM34 temp sensor that outputs 10mv/degree F and I want to use a PIC with a hardware pwm to drive a DC fan. I haven't chosen the pic yet.
    Below 90deg F I need a 0% duty cycle (off), at 90deg F (.900 volts at the pic) a 50% duty cycle and at 120deg F and above (1.20 volts at the pic) I need 100% duty cycle..
    I know you guys are geniuses so I'm hoping someone can come up with a formula for this.
    Thanks.
    Miami, Florida USA
    If I understand correctly your question, when you get .90V out of the temperature sensor that corresponds to 90deg F and 1.20V corresponds to 120deg F. A very simple linear equation crossing the origin (0,0) would be
    Temperature = 100 * Voltage
    Use this simple equation for Temperature in the range between 90F and 120F. I hope this helps.
    Nov 2009
    Wagoner, USA
    I need the fan to come on at 90 deg and output a PWM signal of 50% at that temp. Then increase the duty cycle of that PWM signal as temperature (voltage) increases to a maximum of 100% at 120deg and above.
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by polymer52 View Post
    So basically, assuming the PWM part has 255 steps, when temp = 90 the PW would = 0, and when its 120 the PW = 255 ?
    So that's a 30 degree range represented by a 255 step. 255 / 30 = 8.5
    That would mean that for every degree the PW is 8.5
    You would then need to write your code so that if temp < 90 PW=0 and if temp >120 then PW =255 to give you your range. I would then use a variable to give you the 30 degree steps you need, something like range value = temp - 90, and then use this for the steps, sorta PW= range value X 8.5
    This may not be the ideal way, and I'm sure it could be simplified, but it's the way I would approach the problem. You need to choose a PIC and set the resolution of the PWM you wish to use, the more steps the smoother the fan control will be
    EDIT:
    just re-read your post, you want the fan to run at 50% at 90 degrees, if so then wouldn't that be a simple case of a statement like
    If temp >90 and <120 then PW=127
    If temp > 120 then PW=255
    Hope this helps
    Feb 2005
    brookfield, ct, usa
    Hi Polymer
    try this - I used a 12F683
    Take care
    Alec
    '* Name : fan controller_forum *
    '* Author : Alec Noble *
    '* Notice : Copyright (c) 2010 Alec Noble *
    '* : All Rights Reserved *
    '* Date :1/3/2010 *
    '* Version : 1.0 *
    '* Notes : *
    @DEVICE=PIC12F683
    define OSC 8
    OSCCON = %01110001 ' Internal 8MHz osc
    CMCON0 = 7 ' Comparators off
    WPU = 0 ' Internal pull-ups = off
    'GPIO = %00000000 ' All outputs = 0 on boot
    TRISIO = %000000001 ' GPIO.0=data in, GPIO.2=PWMout, GPIO,1,3,4,5 unused
    '******************** set up ADC ************************************
    ANSEL = %00010001 'gpio.0 analog, others digital, ADC clock fosc/8
    DEFINE ADC_BITS 10 ' ADCIN resolution (Bits)
    DEFINE ADC_CLOCK 1 ' ADC clock source (Fosc/8)
    DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
    adcon0.7 = 1
    '********************* define variables *******************************
    sensor var word
    temp var word
    span var byte
    duty var word
    '********************** intitialize variables *************************
    duty = 0
    temp = 0
    span = 0
    '********************** Program starts here **************************
    HPWM 1, duty, 5000 'set PWM output
    adcin 0, sensor 'read temperature sensor
    sensor = sensor * 500
    temp = div32 1023 'convert ADC to degrees
    span = temp - 90 'get range above 90 degrees
    if temp < 90 then 'less than 90 degrees PWM off
    duty = 0
    if temp > 90 and temp < 120 then
    duty = 130 + (span * 4) 'between 90 and 120 start with 50% and linearly
    endif 'raise rate up to 120 degrees
    if temp > 120 then 'above 120 degrees 100%
    duty = 255
    pause 100 'pause to avoind to frequent cycling
    goto main 'do it again
    California, USA
    I think Malcolm had it... it's about 8.5 PWM steps per degree, over a 30 degree span.
    So, something like this?
    If temp < 90 then
    	duty = 0
    	duty = (temp - 90)  * 85 /10   'subtract 90 from temp, and multiply * 8.5
    steve
    Nov 2009
    Wagoner, USA
    Quote Originally Posted by malc-c View Post
    EDIT:
    Hope this helps
    I think I have settled on the 12F683. It has an 8mhz internal osc, A/D converter and hardware PWM so it doesn't have to be constantly strobed.
    Also the 2k words program memory is a nice touch. I can be as sloppy with my code as I want and still have room to spare.
    Getting closer..Anything below 90deg fan is off so:
    If Temp<90 then HPWM=0
    Then at 90 deg fan comes on at 50%:
    If Temp=90 then HPWM=127 (50% of 255 leaving 127 remainder). 'Minimum fan speed
    Here is the part I don't understand. From 91 to 120 the fan speed needs to vary according to temperature so:
    From 91 to 120 each degree needs to widen the HPWM by 4.23 (remaining 127 / 30 deg) speeding up the fan incrementally by temp.
    Finally
    IF Temp>= 120 then HPWM=255 'Full fan speed at or above 120 deg
    The actual PBP command is: HPWM Channel,Dutycycle,Frequency
    so at 90 deg on channel 1, 50% duty cycle and 1khz rate the command
    would be HPWM 1,127,1000. I can replace the 127 with a variable.
    I f you are asking then yes. You can use a variable.
    California, USA
    Ahh, that's right, the minimum on speed is 50%... (duty = 128)
    So then you've got to increase duty by about 4.2 for every degree between 90 and 120 ...
    How about something along these lines:
    If temp < 90 then duty = 0
    If temp > 120 then duty = 255
    If temp > 89 AND temp < 120 then duty = 128 + ((temp - 90) * 42 / 10)
    steve
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 15:40
  2. Transistor selection, PWM fan control
    By 124C41 in forum Schematics
    Last Post: - 22nd December 2008, 15:33
  3. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
  4. Replies: 9
    Last Post: - 30th August 2005, 06:33
