Automation project need help
Results 1 to 7 of 7
Threaded View
  1. #2
    I like it !
    Typically you would multiply everything by 1000 for .001 resolution .
    Oh, and you're cutting cardboard, forget measuring to .0001 or even .001 especially when you break it into dia/2000 the temp/humidity will kill those resolutions anyway, and seriously just how close does a cardboard piece have to fit? I make parts, mostly for the space/aircraft test industry and I see engineers throw out useless impossible tolerances which serve zero purpose other than make everyone's job harder and swell their ego's. Did a job recently where the engineer told me to bore some holes at the intersection of 2 parts and then take them apart and mill off .002 from 1 surface. Yea right, shimmed it with paper and bored it, on top of that the part it clamped was just a piece of PEX tubing which varied all over the place in diameter.
    I guess what I am trying to say is, make Your own job easy.
    Or turn that feed roller down to 1.9099 and it will roll out 6.000 .
    Last Post: - 8th March 2010, 21:58
  2. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. Help on coding/ selecting PIC chip for project
    By lovemeok in forum General
    Last Post: - 27th July 2006, 20:21
  5. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 08:29
