Hi, I am back again with a problem. This time it looks like the interrupt is serviced but only once and code does not move forward. Can you please have a look at my code and advise me if I am doing it right ?
When power is applied this is what happens:Code:Define OSC 4 ' OSCCON defaults to 4MHz on reset INCLUDE "DT_INTS-14.bas" ; Base Interrupt System INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts Include "modedefs.bas" @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOD_ON & _CPD_ON & _IESO_OFF & _FCMEN_ON & _WUREN_OFF ' Pin Definations are here ToTx var GPIO.2 ToRx var GPIO.3 Monitor var GPIO.4 T1CON=49 main: ' Initialize the processor TRISIO = %011000 CMCON0 = 7 GPIO=0 OPTION_REG = %00000111 WDA.4=1 : WPUDA.4=1 ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _Setval, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM start0: gpio.0=1 ' LED1 start: gpio.1=1 ' LED 2 @ INT_ENABLE TMR1_INT Serin ToRx, N2400,["pp3"],code @ INT_DISABLE TMR1_INT if code=0 then goto start0 ' ELSE CHECK OTHER VALUES FOR THE RECEIVED CODE goto start0 Setval: code=0 gpio.0=0 : pause 200 @ INT_RETURN
1) Both LED1 & LED2 glow
2) LED 1 (gpio.0) goes off
and system stays like this though LED should turn ON after 200mS. Please help me know what am I doing wrong?
