Serin timeout not working properly!
Results 1 to 27 of 27
    Quote Originally Posted by Megahertz View Post
    Column 1 ? What does it mean? Is it putting the ASM code somewhere in the middle of the code? Sorry for my ignorance on this topic.
    Column 1: leftmost column of each line. Asm is picky about where you put things, just start the line with several spaces.
    Nov 2009
    London
    Question Little more help please
    Hi, I am back again with a problem. This time it looks like the interrupt is serviced but only once and code does not move forward. Can you please have a look at my code and advise me if I am doing it right ?
    Define          OSC     4      ' OSCCON defaults to 4MHz on reset
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    Include "modedefs.bas"
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOD_ON & _CPD_ON & _IESO_OFF & _FCMEN_ON & _WUREN_OFF
    ' Pin Definations are here
    ToTx  	             var     GPIO.2
    ToRx		var	GPIO.3
    Monitor		var  	GPIO.4
    T1CON=49
            ' Initialize the processor
            TRISIO = %011000
            CMCON0 = 7
            GPIO=0
            OPTION_REG = %00000111
            WDA.4=1  : WPUDA.4=1
    INT_LIST  macro    ; IntSource,    Label,  Type, ResetFlag?
           INT_Handler    TMR1_INT,  _Setval,   PBP,  yes
    start0:
    gpio.0=1 ' LED1
    start:
    		gpio.1=1 ' LED 2
    @   INT_ENABLE   TMR1_INT
    		Serin ToRx, N2400,["pp3"],code
    @   INT_DISABLE   TMR1_INT
                               if code=0 then goto start0
                               ' ELSE CHECK OTHER VALUES FOR THE RECEIVED CODE
    goto start0
    Setval:
         code=0
    	gpio.0=0 : pause 200
    @ INT_RETURN
    When power is applied this is what happens:
    1) Both LED1 & LED2 glow
    2) LED 1 (gpio.0) goes off
    and system stays like this though LED should turn ON after 200mS. Please help me know what am I doing wrong?
    Sounds like it's working exactly like it should be.
    1. TMR1 interrupts while it's sitting in your SERIN routine waiting for 3 ASCII characters
    followed by the byte that gets placed in code (which by the way hasn't been declared).
    2. Once the interrupt service routine executes, it returns right back to your SERIN
    routine with the LED off.
    Insert a toggle command in your int handler for a quick visual indication of the int handler
    executing. That would tell you it's working or not.
    And -as-is, it's never going to execute any code below your SERIN routine unless all 3 ASCII
    characters + the byte that goes into your undeclared code VAR are received.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2009
    London
    Question
    Hi Bruce, I did that and yes you are right (as always) about it. I Learnt a bit more about interrupts as well while dealing with this problem.
    Can you please advise/explain me how can I make the code jump and move to the next line of Serin with help of Interrupts. I really appreciate your help.
    P.S: This is not the full code, all variables are declared in my code. I just tried to highlight the problem to you with minimum code here.
    I don't know if this is what you had in mind,
    but it could be a possibility for your Timeout wishes.
    With the extra features of the 12F635, you should be able to to create a WDT based timeout for the SERIN or other command(s).
    Starting with the WDT turned off, and DEFINE NO_CLRWDT 1
    And this un-tested code ... (don't have a 12F635)
    DEFINE  OSC     4                   ' OSCCON defaults to 4MHz on reset
    DEFINE  NO_CLRWDT 1                 ' stop kicking the DOG
    CFG =       _INTRC_OSC_NOCLKOUT     ; Oscillator
    CFG=CFG&    _WDT_OFF                ; Watch Dog Timer <-- Very Important
    CFG=CFG&    _PWRTE_ON               ; Power-on Timer
    CFG=CFG&    _MCLRE_OFF              ; Master Clear Reset
    CFG=CFG&    _BOD_OFF                ; Brown-out Detect
    CFG=CFG&    _IESO_OFF               ; Internal External Switchover
    CFG=CFG&    _FCMEN_ON               ; Fail-Safe Clock Monitor
    CFG=CFG&    _WUREN_OFF              ; Wake-up and Reset
    CFG=CFG&    _CP_OFF                 ; Code Protect
    CFG=CFG&    _CPD_OFF                ; EEPROM Data Protect
      __CONFIG  CFG
    INCLUDE "modedefs.bas"
    '----[Pin Definations]------------------------------------------------------
    LED1        VAR GPIO.0
    LED2        VAR GPIO.1
    ToTx  	    VAR GPIO.2
    ToRx        VAR GPIO.3
    Monitor     VAR GPIO.4
    ;----[Variables/Aliases]----------------------------------------------------
    TOaddr      VAR WORD BANK0 SYSTEM
    code        VAR BYTE
    WDTO        VAR STATUS.4                ; WatchDog Timer Timeout bit
    SWDTEN     VAR WDTCON.0                 ; Software WDT Enable
    BAUD        CON N2400
    '----[Initialize]-----------------------------------------------------------
    Init:
        IF !WDTO THEN                       ; If the WDT timed out
          TOGGLE LED2
            movf    TOaddr + 1, W           ; Goto Timeout Address
            movwf   PCLATH
            movf    TOaddr, W
            movwf   PCL
        ELSE                                ; Power-on, or other Reset
            CMCON0 = 7
            GPIO=0
            WDA.4=1  : WPUDA.4=1
            WDTCON = %00010110              ; 1:65536, WDT off
    ;----[Main Program Loop]----------------------------------------------------
        TOGGLE LED1
            movlw  LOW(_TimeOut1)           ; Set the Timeout jump Address
            movwf  TOaddr
            movlw  HIGH(_TimeOut1)
            movwf  TOaddr + 1
            CLRWDT                          ; kick the DOG first
        SWDTEN = 1                          ' enable the WDT
        Serin ToRx, BAUD,["pp3"],code
        SWDTEN = 0                          ' disable the WDT
        SELECT CASE code                    ' CHECK VALUES FOR THE RECEIVED CODE
          CASE 0                            '   Null code, no action
          CASE 1
              ; do code 1
          CASE ELSE                         ' Unknown Code
              ; don't know the code. Ignore or Warn
        END SELECT
      GOTO Main
    TimeOut1:                               ' Timeout occured
        SWDTEN = 0                          ' disable the WTD
        ; notify user of timeout
        ;   or do timeout cleanup
    GOTO Main
    Prior to starting a SERIN command, it saves an address to the Timeout1 Label and starts the WDT.
    If the WDT times out during the SERIN command, the processor will RESET.
    At the top of the program, it checks to see if the reset was from power-up, or the WDT. If it was from the WDT, it was a Timeout, so it jumps to the timeout label that was saved prior to starting the SERIN command.
    All previous Stack levels are discarded. So the label that it jumps to MUST be in the Main loop.
    Timeout period can be adjusted by changing the WDTCON prescaler.
    Food for thought while drinking Champaigne.
    Happy New Year!
    Nov 2009
    London
    Question
    Thanks Darell, it is very interesting how you can go around things in programming.
    Is it possible you can provide PBP statements for the following lines of the code:
    1) TOaddr      VAR WORD BANK0 SYSTEM
    2) ASM
            movwf   PCLATH
            movf    TOaddr, W
            movwf   PCL
    3) ASM
            movwf  TOaddr
            movwf  TOaddr + 1
    Also I wonder if similar way of using WDT can be adopted for 12c671/12F508/16F676 as I have few little projects pending involving these and all of them will have one thing common - A noisy RF receiver attached to one pin
    P.S - No problem if you have not tested the code. I will try to my best to do it first, just after I know the PBP equivalent of the above statements.
    1) is already a PBP statement.
    2) If you really must ... could be changed to ...
    PCLATH = TOaddr.HighByte
    PCL = TOaddr.LowByte
    3) Must stay exactly like it is in ASM.
    With the 12c671/12F508/16F676's, the WDT can not be turned on and off in software.
    So this approach will not work with those chips.
  1. SERIN timeout
    By Del Tapparo in forum Serial
    Last Post: - 20th November 2007, 05:34
  2. SERIN Timeout
    By George in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 16:06
  3. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 08:33
