Serin timeout not working properly!
Results 1 to 27 of 27
    Nov 2009
    London
    Quote Originally Posted by Nicmus View Post
    Hi Megahertz,
    If you want the LED to blink while waiting for input you must jump to your “Main” label after the timeout. Read the Serin command for more information.
    HTH
    Nick
    Hello Nick, that is the problem. The serin command is not working as expected.
    It only jumps to a timeout label if you tell it where the label is.
    high led : pause 50 : low led
    Serin FromRx,N2400,200,Main,["pp3"],code
    .....rest fo the code here
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2009
    London
    Question
    Sorry for the code, I have missed the *Main* while writing the question. It actually is there in my code.
    I will correct my code statements to the following:
    .....rest of the code here
    goto Main
    The code enters main label and led blinks, but then it stops. I expect it to blink after every 200mS which is not happening.
    Couple of times this happened as well that program entered main label, led blinked few times lets say 5 or 6 after every 200mS but then it stopped again.
    I cannot understand this erratic behaviour of my PIC.
    The timeout period gets continuously reset if there's noise on the serial input pin. If you're trying to use this option with a noisy RF receiver, the timeout/label approach isn't going to work.
    -Bruce
    tech at rentron.com
    Nov 2009
    London
    Question
    Are there any other options?
    I tried removing timeout period and use DT Interrupts, but it gave list of following errors.
    Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z   -p12F635 "TxRx.bas"
    PICBASIC PRO(TM) Compiler 2.50b, (c) 1998, 2008 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Variable wsave3 position request 416 beyond RAM_END 127.
    ERROR: Variable wsave2 position request 288 beyond RAM_END 127.
    ERROR: Variable wsave1 position request 160 beyond RAM_END 127.
    ERROR: Unable to fit variable wsave
    ERROR: Unable to fit variable RS1_Save
    ERROR: Unable to fit variable RS2_SaveHalting build on first failure as requested.
    BUILD FAILED: Thu Dec 31 14:13:38 2009
    Open DT_INTS-14.bas and read the first few lines about the wsave errors.
    -Bruce
    tech at rentron.com
    Nov 2009
    London
    Question
    Thanks for showing the starting point. I have fired a bullet in the dark as I do not know much about ASM, banks and stuff. BUT it has reduced the errors.
    I still have few errors left.
    My DT_IN... .bas looks like this now:
    ;wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    wsave       var byte    $70     SYSTEM     ' alternate save location for W
                                                ' if using $70, comment out wsave1-3
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    ;wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    ;wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    And the errors are following:
    ERROR: Unable to fit variable RR2_Save
    BUILD FAILED: Thu Dec 31 16:29:42 2009
    Nov 2009
    London
    Question
    OK, did some lookaround for the problem.
    I have also commented in ReEnterPBP.bas the following
     '   T3_Save     VAR WORD
     '   T4_Save     VAR WORD
    Now it seems that I am quiet near but one warning message is there still :
    Executing: ........"TxRx.bas"
    Warning[206] D:\BACKUP.........TXRX.ASM 752 : Found call to macro in column 1. (INT_CREATE)
    Loaded D:\Backup..................TxRx.COD.
    BUILD SUCCEEDED: Thu Dec 31 16:39:22 2009
    Any advise if I should be bothered about the warning message?
    The 12F635 only has 64 bytes SRAM so if you're using DT ints with a PBP int handler you may need to free up some SRAM, and keep your int handler as simple as possible.
    Hard to say without seeing what you're doing.
    -Bruce
    tech at rentron.com
  1. SERIN timeout
    By Del Tapparo in forum Serial
    Last Post: - 20th November 2007, 05:34
  2. SERIN Timeout
    By George in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 16:06
  3. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 08:33
