Serin timeout not working properly!
Results 1 to 27 of 27
    Nov 2009
    London
    Exclamation Serin timeout not working properly!
    Happy New Year To everyone.
    I am facing a small problem of Serin command. The timeout function is not working correctly. (Using 12F635 with WDT_OFF)
    high led : pause 50 : low led
    Serin FromRx,N2400,200,["pp3"],code
    .....rest fo the code here
    My led should blink 50mS ON & appx 200mS OFF when no data is comming from my RF Receiver. But this is not happening. Can someone help please? Thanks
    Hi Megahertz,
    If you want the LED to blink while waiting for input you must jump to your “Main” label after the timeout. Read the Serin command for more information.
    HTH
    Nick
    Nov 2009
    London
    Quote Originally Posted by Nicmus View Post
    Hi Megahertz,
    HTH
    Nick
    Hello Nick, that is the problem. The serin command is not working as expected.
    It only jumps to a timeout label if you tell it where the label is.
    Serin FromRx,N2400,200,Main,["pp3"],code
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2009
    London
    Question
    Sorry for the code, I have missed the *Main* while writing the question. It actually is there in my code.
    I will correct my code statements to the following:
    .....rest of the code here
    goto Main
    The code enters main label and led blinks, but then it stops. I expect it to blink after every 200mS which is not happening.
    Couple of times this happened as well that program entered main label, led blinked few times lets say 5 or 6 after every 200mS but then it stopped again.
    I cannot understand this erratic behaviour of my PIC.
    The timeout period gets continuously reset if there's noise on the serial input pin. If you're trying to use this option with a noisy RF receiver, the timeout/label approach isn't going to work.
    -Bruce
    tech at rentron.com
  1. SERIN timeout
    By Del Tapparo in forum Serial
    Last Post: - 20th November 2007, 04:34
  2. SERIN Timeout
    By George in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 15:06
  3. 16F628A Serin timeout and Timer1
    Last Post: - 26th March 2006, 23:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 18:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 07:33
