PICkit2 Drving me nuts!!!!
Results 1 to 13 of 13
    Jul 2007
    Default PICkit2 Drving me nuts!!!!
    I can't figure this thing out
    I tried hooking it up countless times and I can't get it to program
    seriously I just wish that I could learn how to program with it
    I tried hooking it up with the ICSP and led and the PIC was smoking from MCLR
    which I'm sure was my fault
    but even before I still couldn't get it to work in the past and no smoking happened
    Any help would be greatly appreciated on helping me program with this thing
    I was using a PIC16F627A
    Its fairly easy to test all the signals on the Pickit2.
    Just load your Pickit2 software, go to Tools-Troubleshoot and follow all the steps, using your multimeter at all stages to confirm what you're supposed to be getting. If all tests pass, your Pickit2 itself should be okay.
    Anand
    Oct 2003
    holland
    Let us see how you connect the PICKIT2 to your 16F627A with the rest of your circuit. Maybe you made some wrong connections.
    Give us a drawing or some good photo's
    Jul 2007
    This is how it was before I hooked up the LED
    Oct 2003
    holland
    That should be no problem.
    If you did it like that and nothing else connected to the chip, it must programm it.
    There is ofcource still another possibility!
    The porgramm you wrote, sucks!
    The rest of your connection and or powersupply is not good.
    Sorry for this language but at this moment nothing else came to my memory.
    Jul 2007
    It was a simple blink circuit and my power supply is a fixed bench top power supply
    I believe I just have a bad programmer because the programmer would say it reads a device and then say it didn't
    I say I should just move on to an Arduino
  1. ICD use with MCS Plus, PBPro & PicKit2??
    Last Post: - 1st October 2009, 00:06
  2. Pickit2 / ICD2? advice please?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 27th May 2008, 19:27
  3. mplap picbasic with pickit2
    By zk_bamx2 in forum General
    Last Post: - 25th February 2008, 04:13
  4. Help MCS with PICKIT2 programmer question
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 18:57
  5. Good news for Pickit2 disapointees
    By websmith in forum Off Topic
    Last Post: - 31st January 2007, 16:54
