Pulsin vs. Interrupt RPM measurement
Results 1 to 2 of 2
    Default Pulsin vs. Interrupt RPM measurement
    Using a 16F877A to measure engine rpm. I have a rpm simulator that connects to a racing ignition system and fires a test plug. The simulator has two outputs, one will fire the ignition system and the other is just a simple square wave. When I use the following Pulsin code I get good data using the square wave and also when making sparks.
    DEFINE OSC 20
    RPM             var     word
    period          var     Word
    HRPM            var     word
    LRPM            var     word
    RPM_Total       VAR     Word
    LCD             VAR     PortC.6    'LCD output
    RPMInput        var     PortC.2
    Prefix          con      $FE             ' needed before each command
    LcdCls          CON      $51             ' clear LCD (use PAUSE 5 after)
    CursorPS        con      $45             'Cursor Position
    loop:
      Pulsin RPMInput, 0, LRPM
      PULSIN RPMInput, 1, HRPM
      RPM_Total = HRPM + LRPM
      RPM = 1000
      RPM = RPM * RPM
      RPM = DIV32 RPM_Total   ' 1,000,000 / Pulse_Total
      RPM = RPM * 60            ' Per minute
      RPM = Div32 8            ' 4 pulses per rev
      SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM ",dec5 RPM]
    goto loop
    When I use the interrupt code I get data that matches the simulator but I get some problems when I create a spark. Once in a while on my LCD I see the correct value however most of the time I get data that is extremely high. What can I do to fix this deal? Initially I was thinking it was purely hardware so I put a 0.1uf cap on the output of the opto-isolator that connects to the RPM pin. It really didn't solve the problem. I have the standard caps on the VDD of the PIC. I am pulling the RPM pin high with a 10k resistor and using the opto to ground the pin. Any ideas?
    DEFINE OSC 20
    Capture         VAR     PIR1.2		      ' CCP1 capture flag
    Overflow        VAR     PIR1.0	    	' Timer1 overflow flag
    RPM             var     word
    period          var     Word
    CCP1CON = %00000110   			' Enable the CCP1 capture, every 4th rising edge
    pause 50
    SEROUT2 LCD,84, [Prefix, LcdCls]
    pause 50
    SEROUT2 LCD,84, [Prefix,CursorPS,0,"**** ",#RPM, " ", #Period]
    pause 200
    loop:
    T1CON = %00100000 ' TMR1 prescale=1:2 Timer OFF
    '11 = 1:8 prescale value
    '10 = 1:4 prescale value
    '01 = 1:2 prescale value
    '00 = 1:1 prescale value
    TMR1H = 0                               ' Zero the Timer
    TMR1L = 0
    capture = 0
    Start:
    	IF capture = 0 Then
        goto Start	' Wait here for the first capture
     T1CON.0 = 1             ' Start the Timer
     capture = 0             ' Reset  the capture flag
    CaptureLoop:
    	IF capture = 0 Then
        goto CaptureLoop	' Wait here until captured
    period.lowbyte = CCPR1L		' Store the captured value in
    period.highbyte = CCPR1H	' period variable
    period = period / 2
    RPM = 10000
    RPM = RPM * RPM ' 100,000,000
    RPM = DIV32 period ' 100,000,000 / RevCount
    RPM = DIV32 400
    RPM = (RPM /10)*25'+25
    SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM ",dec5 RPM, " ", #Period]
    gosub cleartimer1
    GoTo loop					' Do it forever
    ClearTimer1:
    IF (capture = 0) Then
      goto cleartimer1	' Wait for beginning of next period
    TMR1L = 0					    ' Clear Timer1 low register
    TMR1H = 0					    ' Clear Timer1 high register
    capture = 0					    ' Clear capture flag
    overflow = 0				    ' Clear overflow flagReturn
    Default Noise on OSC pins.
    Using a 18F4620 configured for a 20MHZ external OSC. When I generate spark with my ignition the OSC pins go low and spike with ignition firing. Any ideas?
  1. 16F877@4Mhz calculate Pulsin to RPM
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 15th June 2013, 16:42
  2. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 16:12
  3. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  4. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 04:33
    Last Post: - 6th March 2005, 01:07
