Interruption
Results 1 to 15 of 15
Thread: Interruption
    Aug 2003
    An interrupt is overkill for this, and not the typical way to handle the problem at all.
    I'd use a counter to have your button checked every 10ms, and LED routine run every 500ms like this.
    and you get to save the interrupt for when it's actually needed.
    x var byte
    direction var bit
    timerbyte var byte
    TRISA = 1
    TRISC = 0
    x = 1
    loop:
    PORTC = x
    pause 10
    timerbyte = timerbyte + 1
    IF PORTA.3 = 0 then
    IF direction = 0 THEN
    direction = 1
    direction = 0
    ENDIF ' direction
    ENDIF ' button
    IF timerbyte = 50 THEN timerbyte = 0 ' 500ms has passed if timerbyte = 0
    IF timerbyte = 0 THEN
    	IF x = 8 THEN x = 1
    	x = x << 1
    	IF x = 1 THEN x = 8
    	x = x >> 1
    ENDIF ' direction
    ENDIF ' timerbyte
    goto loop
    Overkill????
    Please explain.
    Aug 2003
    Thought I already did.
    It's using hardware to do what should and can be done in software.
    Like wiring a circuit to turn the pic's power off to turn an LED off.
    and developing bad habit at the same time, and not learning anything.
    Well after you made an edit to your post you have some explanation.
    Looping back through the code every so often to check on a button smells like some sort of pasta to me.
    Maybe the OP should learn to use the hardware. Then when the code grow to more than a few lines......
    Wait a minute. Your joking, right?
    Using an interrupt is forming bad habits.
    Now I get it.
    NOT!
    Aug 2003
    When it's not needed, I think it is.
    What if the platform didn't support interrupts?
    I think using an interrupt when it isn't needed is forming a bad habit.
    The loop is happening anyway, and I have one less label in my code.
    It's less spaghetti than the original which doesn't run in one single loop.
    An interrupt would add more spaghetti in the generated asm to goto 0x04.
    This is a simple program, but as it grew, you might need an interrupt for something else.
    EDIT; ps I edited to edit the program, but haven't actually run it.
    if it has any issue, it still offers a solution.
    Fair enough.
    Good to see all possible solutions and reasons for the solutions.
    I'll give it a shot with a simple ON INTERRUPT version.
      x var BYTE
      Switch VAR BIT
      TRISA = $FF
      TRISC = 0
      ANSEL = 0            ' A/D disabled (all digital)
      ANSELH = 0
      IOCA.3 = 1           ' int-on-change enabled for RA3
      INTCON = %10001000   ' enable global & int-on-change interrupts
      Switch = 1
      ON INTERRUPT GOTO MyISR
    mainloop:
      x = 1
    loops:
      PORTC = x
      if switch = 1 then
         if x == 8 then
            goto mainloop
            x = x << 1
            goto loops
        if x == 1 then
           x = 8
           goto loops
           x = x >> 1
          goto loops
      GOTO mainloop ' just in case
      DISABLE
    MyISR:
      WHILE PORTA.3=0  ' wait for button release (so we can clear the int flag & be
      WEND             ' sure it interrupts on a high-to-low transition)
      Switch = ~Switch ' toggle Switch
      INTCON.0 = 0     ' clear interrupt flag bit
      RESUME
    There must be ten gozillion ways to do something like this, even without an interrupt, but
    it's still handy to at least learn about interrupts.
    Note that you could also do something similar by just monitoring the interrupt flag-bit with
    global interrupts disabled. You just need to get a tad more creative...;o}
    Tap & release the button as fast as you can to see how quickly it reacts.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2009
    x var byte
    direction var bit
    timerbyte var byte
    TRISA = 1
    TRISC = 0
    x = 1
    loop:
    PORTC = x
    pause 10
    IF PORTA.3 = 0 then
    direction = 1
    direction = 0
    ENDIF ' direction
    ENDIF ' button
    	IF x = 8 THEN x = 1  <- You forgot that if x = 8 and then x = 1 you must  go to loop or else x will never be 1 but MORE than one
    	x = x << 1
    	IF x = 1 THEN x = 8  <- Same here
    	x = x >> 1
    ENDIF ' direction
    ENDIF ' timerbyte
    goto loop
    I have pointed out some mistakes. Thanks for your code man anyway, cool way to do things, much better than ON INTERRUPT I believe. Don't be too harsh on me guys I've been learning this for less than a week
    I would say you're definitely doing good for someone just getting started.
    It's nice here since you find so many various ways of doing something, which really
    helps one to think outside-the-box. Embedded programming is just creative problem
    solving, and you'll find a lot of different creative approaches around here for
    sure.
    Which one is best for your application is totally up to you.
    -Bruce
    tech at rentron.com
    Dec 2009
    Thanks Bruce, you just pointed out the reason why I love programming and why I love programming a micro controller is because you can see the results in real life, not only digitally.
    Thanks, really
