a little help with capacitive power supply values
Results 1 to 40 of 82
    Feb 2003
    Quote Originally Posted by Dennis View Post
    Keith ..AWESOME reply!
    So from that statement we should assume COMMON LIVE is the supply of choice (in terms of being a little safer) not COMMON NEUTRAL ? Assuming of course that this circuit is indeed a COMMON LIVE circuit ?
    Living in a country where every mains outlet is a 3 pin socket so polarity reversal is impossible unless the actual outlet is incorrectly wired I would say that common live *should* be the supply of choice particularly if the load it was controlling was external to this box of tricks so that it would be recieving a correctly switched supply.
    Irrespective of supply polarity, becuase this circuit is tied directly to one leg of the mains supply it should be totally enclosed and should never be worked on except via an isolation transformer.
    All "basic" light dimmers have a common live supply as they are only connected to the live and load.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Hi again
    Nice one keith ...safety and isolation for sure! Have you read the earlier posts ?
    And those plugs quite often contain fuses (probably on the LIVE) not so ?
    And the looking at the APPNOTE that I referred to in post #1 under the designing for safety heading you would see the fuse placed on one of the lines as well as a fuse and a bleeder/'safety' resistor sitting parallel with C1.
    Now let's chat about the 2 prong device that need to be plugged in the countries you're referring to.
    We need some sort of adapter to plug the 2 prong device into the 3 prong plug right ? Does th adapter contain a fuse as per country electrical regulations (if any ) ?
    So again plugging a PSu like this one into the adapter, one can plug in either way ... and yet again NEUTRAL and LIVE are switched around (in the circuit of course)!
    If this indeed is the case then we are right back at the million dollar question
    "Is this circuit Common LIVE or COMMON NEUTRAL ? And why ?"
    And then we must look at the designing for safety aspects where we discussed fuses.
    One of the original draughts had two fuses , one on each line, and a point or two were raised about one of the fuses (the one on the neutral line) would be pointless. Yes indeed it probably would be useless as well as unsafe ...IF this circuit contained an earth(real ground) !
    But alas, the circuit has no earth point or connection at all !
    SO it seems this circuit will always 'FLOAT' either at 5volts(or whatever you designed it for) below live or 5Volts above neutral.
    In earlier posts I showed circuit diagrams of common live and common neutral from various references.Circuits with components changed around, in different places forcing flow in different directions.
    Are these circuits incorrect ?
    Sadly I don't have an oscilloscope or an isolation transformer at my disposal anymore but I certainly will check/test/build blow-up each circuit depicted and feedback so we can continue this discussion.
    Anyone feel like building a calculator to calcualate the APPNOTE referred to in post #1 and/or the circuit in #66 ?
    Regarding the 'BOX OF TRICKS' you mention ...
    If all of you that are following this post have some time , go and google for 'Ben Franklin flyng a kite in the rain with a key tied to the string' to attract lightening strikes.
    And then along the lines of safety and climate change try google H.A.A.R.P.
    Sure... why not try heat the ionosphere at it's thinnest points at the poles to blow a hole in it just to see what happens .. now that's safety for all mankind not so ?
    All thanks to folks like Tesla, Franklin and ...aaargh let's not go there!
    And is the H.A.A.R.P experiment over ... well apparently (will we ever really know?), but google earth and satellite pics show the facility plain as day !
    Oh well at least we can get answers about the PSU circuit :-)
    Kind regards
    Dennis
    Default It's suddenly gotten really quite in this thread :-(
    Hi guys ...
    Why so quiet ?
    Just a quick post to let you all know I'm still around ... no explosions, shocks or fire yet !
    The test PSU is still working...
    I got busy with real work suddenly and haven't had a chance to experiment more :-(
    Will definitely update on the weekend !
    Kind regards
    Dennis
    Feb 2008
    Michigan, USA
    Default Couldn't resist
    In case some of you didn't see this in another thread.....
    www.picbasic.co.uk/forum/showthread.php?t=2736
    any news on the code from Kamikaze47, seems to have disappeared.
    You are right. Last seen, June 2006.
    You expect to see people disappear from threads labeled:
    Interfacing AC power lines....
    ...transformerless DC supply...
    How to design without opto-couplers ...
    How to measure high voltage while standing in a bucket of water...
    But not from a thread labeled, “AT/PS2 Keyboard - PIC Interface?” ?
    Then again we have to consider his user name!
    Kamikaze47 where are you??
    Apr 2006
    New Hampshire USA
    Smile Quote from the past...
    Quote Originally Posted by Pic_User View Post
    Bo quoted from the past: 30th March 2007, 14:10, not currently.
    Kamikaze47 has been back many times since the original posting.
    See also Melanie’s hilarious post (standing in a bucket of water) #33 two below this quote!
    http://www.picbasic.co.uk/forum/show...0&postcount=33
    -Adam-
    Default The silence has been deafening!
    Deafening silence defined is :
    'A silence or lack of response that reveals something significant, such as disapproval or a lack of enthusiasm'
    Bo ....
    Definitely some valid chirps :-) apparently apparitions do re-appear and it's not all smoke and mirrors :-).
    Now I'm wondering if you have are planning to interface and AT/PS/2 keyboard to the AC mains line that delivers a different 'ZAP' at each keypress ?? Could it be solar-powered or we gonna just stick to the original hookup to directly the substation on 3-phase ?
    The silence in this thread has me a little worried too since i haven't seen Steve around since I asked about some possible measurements (In the post before he said he wasn't to do a few measurements 'cos of his trusty isolation transformer ), I haven't seen any activity on this thread from him since then.
    And all of a sudden this thread went extremely quiet...!
    Shocking I tell you !
    Kind regards
    Dennis
  1. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 01:12
  2. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 18:05
  3. Need advice for 74VDC power supply
    By Christopher4187 in forum Off Topic
    Last Post: - 4th March 2007, 21:54
  4. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
  5. Dual Power Supply Design
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 17th October 2006, 05:11
