a little help with capacitive power supply values
Results 1 to 40 of 82
    Dec 2005
    Quote Originally Posted by Byte_Butcher View Post
    If you really *must* build a transformerless supply, goto the document I referenced in post #17, scroll down to page 10, figure 10 and build it just like that.
    Steve, isn't that the same document Dennis referenced in post #1 of this thread?
    Dec 2005
    Dennis,
    You might also find Microchip AN236 helpful. It has a capacitive supply, a ZC detector and a triac.And there are more schematics of X10 modules on NASA engineer Dr. Ed Cheung's site.
    Default still researching ...
    Hi All
    I'm still busy trying to get my head around all the valuable info you have offered and definitely am taking the time to read through as much as my already overloaded mind can take !
    Melanie and anonymouse thanks for the tip regarding the fuse on the NEUTRAL line :-) , I have updated the schematic to reflect only a single fuse on the LIVE line !
    And thanks again Melanie for the info regarding the OPTO and the TRIAC,
    the reason the TRIAC is open ended is because I have not decided what value to use for the TRIAC, since I think this may be dependent on the choice of PIC (and PORT) ? The designs I have seen so far seem to indicate somewhere between 470R and 1000R for the TRIAC resistor (R3 in my diagram).
    Two things should me taken into consideration here :
    1. the TRIAC gate currents (MIN and MAX)
    2. the PIC pin allowable current
    PLEASE CORRECT me if I am wrong!
    In the meantime I am reading through this as a start!
    http://www.microchip.com/stellent/id...pnote=en011202
    What's of concern is that Microchip have made no mention (that I can see) of the differences between a COMMON NEUTRAL or COMMON LIVE design in the appnotes !!
    Steve,thanks again for the tip especially for the transformer info ... READ the posts to date very carefully please... we have already established that the Microchip design is a COMMON LIVE design which 'floats' 5V below either 120VAC or 220/230/240VAC and that it would be a whole lot 'safer' to rather 'float' 5V above NEUTRAL, hence the changed design thus far.
    Also as Dave pointed out, I did mention in post 1 that I would like to use a transformer-less PSU.
    Dave .. thanks so much for the continuous valuable x10 references as well as the tips thus far.
    That appnote sure has a lot of info and someone went through a huge amount of work to setup the application to get it to that stage I'm sure (especially looking at the section for the tuned circuit replacement of the usual x10 120KHz tuned transformers), is that mains injection being done purely with a resistor and a cap ?
    I saw a project a few days ago where the designer is injecting a 135KHz pulse into the carrier and was wondering if that could be done with the pulsin pulsout command instead? Will see if I can find it for you since I think it may interest you as well.
    Dave and Melanie (and anyone else)... regarding a zero-crossing sensor (which may be needed for dimming), where would you best situate it in this circuit ?
    I have seen various designs indicating it in different places, and most have one of the PIC pins connected with a resistor in series directly to
    For all those following this thread, please note that nothing has been built as yet and the attached schematics are merely used for the discussion.
    Please also take note of ALL the safety warnings!
    Thanks to everyone for all the info so far!
    Kind regards
    Dennis
    Last edited by Dennis; - 4th January 2010 at 01:02. Reason: Found more info..reagrding TRIAC and zero-crossing
    Default more info here
    I have been reading through this appnote http://ww1.microchip.com/downloads/e...tes/40171a.pdf and noticed the presence of two extra capsacitors namely C1 and C2 in the appnote schematic ..what is the function of these in this instance?
    I have updated my design (see attached file) to include a zero-crossing sensor and have connected the TRIAC.
    My concern is the value of the TRIAC resistor and that's the reason for the ???.
    If there are any suggestions/concerns or changes to be made please let me know.
    Kind regards
    Dennis
    Default update
    Forgot to attach the update.
    While checking out various design for PSU's I noticed one person remarked that he might move the Varistor put the varistor after the 47R, so it doesnt have to short out the power station on spikes, same with the 20M resistor.
    He also suggested he would not use a 20M but a rather an attenuator, say/guess 220K and 5k to ground.
    Any thoughts around this statement ?
    PLEASE NOTE - I have also added a WARNING for anyone who might stumble across this !!
    Kind regards
    Dennis
    Default schematic not attaching again ??
    Trying to attach the schematic again (renamed this time)
    Dennis
    Dec 2005
    Quote Originally Posted by Dennis View Post
    Search the forum for Anand Dhuru's posts on building his own X10 modules for 230V. I believe he is using the hardware PWM to generate 120kHz. Also, Darrel Taylor made some modifications to the PBP XOut command that might be of use.
    Default something odd ...
    Hi all
    Dave .. thanks once again for the extra info and tips :-) they always provide good reads and info :-)
    Melanie,Steve and anoymouse...
    While re-reading the Microchip appnotes, this one in particular
    I noticed some interesting points...
    Firstly this one regarding the current draw,
    The PIC12/16/17 microcontrollers draw a maximum of 10 mA, even at the highest frequency and voltage of operation, therefore low current availability is not an issue. AC line voltage isolation can be addressed by using MOVs or transient suppressors on the PIC12/16/17.
    and then something strange about the FUSE on the NEUTRAL LINE ???
    In most applications, the output voltage should be reg-
    ulated. Figure3 shows a diagram for a practical circuit
    where a +/- 5V regulated output is generated. Note that
    the neutral is connected to ground through a fuse. This
    +5V
    would guard against improper AC wiring.
    Any comments on these statements?
    Kind regards
    Dennis
    Where did you get the second quote? The one about the neutral.
    Have you checked your local electrical codes about the proper way to wire something for the system you have? Might clear up the neutral thing for you. Here the ground and neutral are "bonded in the box" not at the device. I can not see yours being any different, I am sure you have a transformer with a center tap providing power to you.
    BTW, you never said why you want to do this or what you think the benefit will be.
    Hi Dave
    Thanks for tip, I was going to get eyes in on the local sub-station but will do so tomorrow ;-) and update as soon as possible :-)
    The quotation is actually from a Microchip appnote TB008 , the paragraph is just above figure 3. in the appnote. [HTML]http://ww1.microchip.com/downloads/en/AppNotes/91008C.pdf[/HTML]
    Ok the project is for the PIR-sensor based security lights, I need to tap into the PIR and replace the existing LDR and sensor circuit which are also transformer-less and triac controlled. Each sensor light PIC transmit back to a central PIC.
    Given the space I have I cannot fit a transformer based supply into the housing or wall point (someone did a good job installing them) and there is no way I can mount the circuit externally.
    So transformer-less it is !
    I have seen circuits aplenty on the web yet it seems most are common live and also mainly for 120VAC it seems.
    Some even with dual fuses (one on LIVE and one on NEUTRAL!)
    So it seems there is quite a lot of confusion in this arena and for good reason I suppose, fear of death being the ultimate reason people shy away and of course once bitten twice shy(being shocked into submission certainly shys people away).
    So my quest was to research the topic of transformer-less supplies before I dive into anything like building one only to encounter serious injury and the possibility of my circuit frying !
    Nothing I have seen out on the web quite explains how one should wire things up on the pic if you're using a transformer-less PSU.
    So appnotes are created and design note etc ... but the very simple steps seem to be missing, the questions (FAQ's) and their solutions.
    So how do we find news ways of doing things if we are stuck designing only in the confines of a transformer-based supply.
    In the early years I remember learning about the effects of capacitive, inductive and resistive circuits.
    For example :
    With a CAPACITIVE circuit, A current will flow through the circuit, first in one direction, then in the other.
    No current actually flows through the capacitor. Electrons build up on the one plate and are drained off from the other plate in very rapid succession, giving the impression that the current flows through the insulator separating the plates.
    However, a capacitor in an AC circuit does offer resistance to the overall current flow. We define a quantity called the CAPACITIVE REACTANCE, Xc,
    In the designs I have seen, people place and swop around the components as the desire almost as though it's a little slap-dash design which may or may not work and your mileage may vary.
    For example, I changed my original circuit design around to make it safer (which was a copy and make-up of the Microchip appnotes (or close to it ) , why would they suggest such an unsafe circuit I wonder ?
    Then I keep getting told to use the Microchip designs ... yes I would love to but are they the safest ? And most if not all of them are for 120VAC without worked examples for 220V or 230V.
    You may have already noted that there COMMON HOT(LIVE) and COMMON NEUTRAL transformer-less supplies.
    So after having changed the initial part of the circuit to make it a common neutral supply , this raised more questions
    what then? , what else needs to be changed ?
    Are the diodes and other components correctly setup and placed the correct way around ?
    And as regards the benefits... well
    1. it is space saving,
    2. is cost (the tiny transformers are extremely expensive here) and
    3. is that I can go extremely small if I use SMD components not so ?
    I have to put the same circuit in about 15 lights.
    If you do manage to see a mistake please let me know.
    Anyways that it from me.. I hope that exaplins it so far :-
    Kind regards
    Dennis
  1. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 00:12
  2. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  3. Need advice for 74VDC power supply
    By Christopher4187 in forum Off Topic
    Last Post: - 4th March 2007, 20:54
  4. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 12:27
  5. Dual Power Supply Design
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 17th October 2006, 04:11
