The efficiency of a Transformer at 50/60Hz is dependent on the amount of iron in it's core... once you drop below about 1.5VA (which is just over an inch cube with an EI30 core) the amount of iron is so small that half the power consumption is used just to heat up the core and windings the efficiency plummets to only 50% or less.
