Hi all
Melanie..
Regarding SMD, I have seen some designs showing SMD components placed after the rectification section section, is it a bad thing to consider SMD in a transformer-less design ?
The voltage ratings are 0805 = 150V and for 1206 = 200V it's quite a whack but not enough for the rectifying stage here.
Would you suggest I utilize that PSU degin you posted mentioned in #2 ?
Just curious as to why the MOV is placed where it is ?
EDIT **** OK I saw it in the forum post ..It's to accomodate for a weakspot at the the zener ****
Did you ever try replacing the 5V regulator with a 5V1 or 5V6 zener instead ?
Have you had any strange anomalies in the PSU's use ?
Have you had any blow?
Is there any ripple or noise encountered on the outputs ? The reason I ask is because I was wondering if it would be ok to add a wireless module to the circuit which the supply would power.
Steve.. the prices certainly are expensive and even for an X2 cap no surface mount !
Those transformers you found certainly are well priced !
Regarding the PIR sensors ...WOW and they do what they do at such a low voltage too ...awesome!
You could easily pack something like that into a matchbox or smaller and have it as a bed-side alarm !
Problem is that it would trigger every time either you or your partner moved in your sleep :-)
Will definitely be looking into those too !
Keep well
Kind regards
Dennis
