PIC KIT 2 writing problem ?
Results 1 to 3 of 3
    Dec 2009
    Default PIC KIT 2 writing problem ?
    Hello,
    There is a strange problem, i will be very happy if solve it.
    I am using windows 7 64-bit as operating system. It is the first time that i use PicKit2 on this o.s.Also my PBP compiler version is 2.46. I am using Pic16F84A (doesn't work on 16F678A either)
    Here is the situation:
    I can succesfully select, import and write hex file on PIC. But when i put the pic to the circuit, it doesn't work. I track the problem. Circuit is Ok. I select to read the Pic, but PicKit2 shows me only 0000 in the program memory,it shouldn't be like that is it not?
    Bombay, India
    you have the configuration set to all protect. You cannot read anything other than 00s from the pic in this condition, so, there is no problem there.
    Dec 2009
    Thank you, it was a little mistake .By the way i didn't find the problem. I reinstalled the program and now it is working properly.
  1. PIC stop responding - Strange Problem!
    Last Post: - 31st August 2009, 14:06
  2. 5v for PIC problem
    By financecatalyst in forum Schematics
    Last Post: - 24th August 2009, 16:04
  3. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 00:39
  4. how to connect 2 LCDs on a PIC
    By f1fco in forum mel PIC BASIC Pro
    Last Post: - 15th April 2004, 17:59
  5. Serin2/Serout2 PIC 2 PIC
    By actionplus in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2004, 06:46
