Hi Darrel,
Many thanks, it does help a lot!
So, can I assume that it takes roughly the same time to "get out of" an ASM interupt as it takes to enter it, in this case 8.4uS? Then, theoretically, the max frequency would be 1/(2*8.4+1uS) = 56kHz - if all it had to do was servicing the INT2 interrupt - which unfortunately still isn't good enough :-( Even going to 40Mhz just barely gets me over the 100kHz target with not much time left to do anything.
I know the 8bit buffer variable may "look" limiting but because it is "read" by the servo-loop, which is currently run at 1220Hz, it means the actual limit would be ~155kHz - if I can get that I'd be happy. The only concern I have with this approach is that I need to disable the INT2 interrupt while reading and resetting the buffer. But if I'm not mistaken if an interrupt occurs during this time it will get "latched" and serviced as soon as I re-enable it again.
Thanks again Darrel! I'll give it a go during the day and see what I can get.
PS. I have a comercially available drive that I bought which also uses the 18F2431, it has a claimed step-frequency of 400kHz - I wonder how they do it....
