Multiple "AND"'s in select case?
Results 1 to 5 of 5
    Nov 2009
    Wagoner, USA
    Default Multiple "AND"'s in select case?
    Does Select case not allow and's in one line?
    Here is a snippet.
    Even when all is true it ignores the first 2 lines.
    Background:
    pv = current photovoltaic voltage (varies 0-34v)
    pvhigh = voltage to turn on both grid tie inverter and battery charger (13.5v)
    pvmin = minimum pv voltage to shut down system (12.0v)
    batt = current battery voltage
    battmax = maximum battery voltage (13.2v)
    Select Case pv
        Case is >= pvmin and pv >= batt and pv <= battmax
            gosub ChargeBatt	               'Turns on batt relay
    	Case is >= battmax and batt >= battmax
        	gosub gridtie                      'Turns on inverter relay
        case is >=pvhigh
            gosub AllSystems                'Turns on both relays
    	Case else                          ' < pvmin. Turns off both relays
       	gosub standby
    end Select				' Resume here after case is executed
    Now if I delete the ands it will jump to the subs.
    Select Case pv
        Case is >= pvmin
    	Case is >= battmax
        case is >=pvhigh
    	Case else
       	gosub standby         ' < pvmin. Turns off both relays
    Jan 2006
    Istanbul
    Post
    This should work
       Case is >= pvmin and is >= batt and is <= battmax
    But this one seems to be better,
       Case is >= pvmin
            if pv >= batt and pv <= battmax  then etc...
    Nov 2009
    Wagoner, USA
    Quote Originally Posted by sayzer View Post
    This should work
       Case is >= pvmin
    Thanks. I'll try that tonight when I get back home.
    Dec 2005
    Salt Lake City, Ut, USA
    I got tripped up with this one too...
    Needs to be along the lines of:
    Case is >= pvmin
            if (pv >= batt) AND (pv <= battmax)  then etc...
    Good luck and happy coding.
    Chris
    Nov 2009
    Wagoner, USA
    Works great. Thanks guys.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
