DS1307 and a LED array, need ideas
Results 1 to 13 of 13
    Feb 2005
    Question DS1307 and a LED array, need ideas
    Hi, I want to do two things at once, and I don't know how
    Let me explain, I want to update a led matrix (12x12) this needs to be done real fast so the eye, due to persistance of vision , thinks all the leds are on at the same time, but also I want to poll a DS1307 RTC to keep time.
    So, how do I do both things at the same time? I mean if I pause between reads the led display does not show, and if I read the clock in the led matrix refresh loop I choke the DS1307 with too many requests.
    Speed is no problem because Im going to use a 18F4550 or one of its relatives (depending on the amount of data I will need to store)
    I think the solution is around interrupts, but I never programmed with interrupts, so Im kinda lost here... Im not asking for code (it wont hurt to read some thou) just some pointers so I can figure it out what to do with some datasheet reading.
    thanks
    How long does it take for the display loop?
    How are you driving the display? Direct or shifting out through a driver chip?
    When you say real fast... keep in mind that for most folks the blink goes away at around 30 Hz. Should leave plenty of time someplace.
    How often do you want to read the RTC?
    Mar 2009
    Colorado
    Default Some sample interrupt code for DS1337
    Quote Originally Posted by peu View Post
    ... Im not asking for code (it wont hurt to read some thou) ....
    You're on the right track to consider an interrupt. Search this forum for how to use Darrel Taylor's Base Interrupt System...you need to download his DT_INTS-18.bas and ReEnterPBP-18.bas files and make them INCLUDEs in your code. Am currently working on an application that uses this approach for an 18F4550, but with a DS1337 real-time-clock rather than the DS1307. DS1307 is almost identical to DS1337 except for 2 pins and the register addressing...suggest you get the data sheets for both and compare and you should be able to quickly see how to modify this example code to make it work with DS1307.
    Here is the setup from the example code. If you are interested in all the code I can email it to you...too long for this posting. Ask questions and I will try to help you. This forum has been very good to me so I welcome the opportunity to do some payback.
    ' [ Program Description ]
    '  This Program is for a PIC18F4550 & was tested in an EasyPic6 board. *
    '  Purpose:	                                                             *
    '    1)  Monitors 1/min interrupt from external Real Time Clock          *
    ' [ Device Declaration
    ; if you un-comment these, you must comment the ones in the .inc file--
    ASM ; 18F2550/4550, 8mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC4_PLL6_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    Include "Modedefs.Bas"
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP high priority interrupts
    INCLUDE "ALLDIGITAL.pbp"    ' Sets all registers for digital ops.
    DEFINE OSC 16
    ' Initialize Hardware
        'Set registers
          TRISA = 0             ' PORTA all outputs
          TRISB =%00001100      ' RB2 & RB3 set as RTC Alarm1 & Alarm2 inputs
          TRISC = 0
          TRISD = 0
          TRISE = 0
    ' Variables & Aliases for Pins other than RTC use
    b0        VAR Byte       ' LSB of range measurement when right justified
    b1        VAR Byte       ' MSB of range measurement when right justified
    'SETUP FOR USING DS1337 Real Time Clock
    ' Setup Hardware for uart
        DEFINE HSER_BAUD 115200
        DEFINE HSER_RCSTA 90h
        DEFINE HSER_TXSTA 24h
        DEFINE HSER_CLROERR 1
    ' * NOTES for use with EasyPic6 development board:
        'For interface to DS1337 RTC:
    '     - To provide battery backup place a Shottky diode between + battery
    '       terminal and Vcc (pin-8) of the DS1337.
    '     - I2C communication lines should be connected to 4.7K pull-up resistors.
    '     - INTA & INTB lines should be connected to pull-up resistsors.
    '     - Turn off LEDs connected to I2C communication lines.
    ' Aliased Variables for CLock
        Alarm1      VAR PORTB.2     ' Alarm1 input from DS1337 INTA (pin-3)
        Alarm2      VAR PORTB.3     ' Alarm2 input from DS1337 INTB (pin-7)
        SCL         VAR PORTB.1     ' I2C clock pin
        SDA         VAR PORTB.0     ' I2C data pin
        RTCdevice   CON %11010000   ' RTC device write address(byte addressing)
        ' A list of possible  clock contrl settings, one which must be
        ' setup in the SetTimeAndDate subroutine.
         'contrl     CON %00000101   ' Starts oscillator, enables INTA interrupt
                                    ' from A1F, INTA/SQW off.
        'contrl     CON %00000110   ' Starts oscillator, enables INTB interrupt
                                    ' from A2F. WORKS OK!
    ' RTC Address definitions
        SecReg      CON $00   ' seconds address (00 - 59)
                              ' MSB of SecReg must be set to a 0 to enable RTC
        MinReg      CON $01   ' minutes address (00 - 59)
        HrReg       CON $02   ' hours address (01 - 12) or (00 - 23)
        DayReg      CON $03   ' day address (1 - 7)
        DateReg     CON $04   ' date address (01 - 28/29, 30, 31)
        MonReg      CON $05   ' month address (01 - 12)
        YearReg     CON $06   ' year address (00 - 99)
    ' Alarm 1 Address definitions
        Alm1sec     CON $07   ' Alarm 1 seconds address (00 - 59)
        Alm1min     CON $08   ' Alarm 1 minutes address (00 - 59)
        Alm1hr      CON $09   ' Alarm 1 hours address (01 - 12) or (00 - 23)
        Alm1Day     CON $0A   ' Alarm 1 day address (1 - 7)
    ' Alarm 2 Address definitions
        Alm2min     CON $0B   ' Alarm 2 minutes address (00 - 59)
        Alm2hr      CON $0C   ' Alarm 2 hours address (01 - 12) or (00 - 23)
        Alm2Day     CON $0D   ' Alarm 2 day address (1 - 7)
    ' Alias of Clock register addresses
       ContReg     CON $0E         ' CONTROL register address
       StatusReg   CON $0F         ' STATUS register address
    ' Clock Variables
        sec         VAR BYTE  ' seconds
        MINs        VAR BYTE  ' minutes
        hr          VAR BYTE  ' hours
        day         VAR BYTE  ' day
        date        VAR BYTE  ' date
        mon         VAR BYTE  ' month
        yr          VAR BYTE  ' year
    ' ALARM1 VARIABLES
        A1sec       VAR BYTE  ' seconds
        A1MINs      VAR BYTE  ' minutes
        A1hr        VAR BYTE  ' hours
        A1day       VAR BYTE  ' day
    ' ALARM2 VARIABLES
        A2MINs      VAR BYTE  ' minutes
        A2hr        VAR BYTE  ' hours
        A2day       VAR BYTE  ' day
    GoSub SetTimeAndDate        ' Setup current time & alarm settings
    'SETUP FOR INTERRUPTS
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            ;INT_Handler   USB_Handler
            INT_Handler   INT2_INT,        _Alarm,   PBP,  yes
        INT_CREATE                ; Creates the interrupt processor
    @    INT_ENABLE   INT2_INT     ; enable external (INT) interrupts
        INTCON.7 = 1         ' Set Global Interrupt Enable bit
        INTCON2 = %00000000  ' Set INT2 for falling edge (Bit4-low)
                             ' on RTC's interrupt.
        INTCON3 = %10010000  ' Set INT2 high priority (Bit7-high), enable INT2
                             ' (Bit4-high)
        RTC_INT_FLG  VAR INTCON3.1 'Alias for RB2 INTA interrupt flag from RTC
    '[ Begin Main Program Loop ]
         GoTo Main        ' Endless Loop waiting for interrupt
    End     ' Safety measure to insure program stops if reaches here
    '[ Begin Interrupt Handler
    Alarm:
       'Put your interrupt service routine code here
        ' Process the RTC alarm
           ' Read the current time and ALARM settings from the DS1337
            I2CRead SDA, SCL, RTCdevice, SecReg,[sec,MINs,hr,day,date,mon,yr]
            Pause 1000
            ' Clear the Alarm flags to be ready for next intterupt
                    ' Clear STATUS register
                    I2CWrite SDA, SCL, RTCdevice, StatusReg,[$00]
                    Pause 1000
                    WRITE 255, sec
                    PAUSE 20
            RTC_INT_FLG = 0      ' Clear PIC interrupt flag for next Alarm
        PAUSE 1000
        ' Resume Main Program
    @ INT_RETURN
    '{ End of Interrupt Handler }
    ' [ START LIST OF SUBROUTINES
    SetTimeAndDate:  ' Subroutine to set current time, date and alarms
    ' Initialize clock variables to 0
        yr=0:date =0:mon =0:day=0:hr=0:MINs=0:sec=0
        A1sec=0:A1MINs=0:A1hr=0:A1Day=0
        A2MINs=0:A2hr=0:A2day=0
    ' The BCD constants below set the RTC to: 11:00:00 on 12-20-2009
        hr=$11
        MINs=$00
        sec=$00
        day=$07
        mon=$12
        date=$20
        yr=$09
    ' Per MAXIM TechSupport, proper sequencing requires setting INTCN = 1,
    ' & A2IE=A1IE=0 before setting alarms.
        I2CWrite SDA, SCL, RTCdevice, ContReg,[%00000100]
        Pause 20
    'Define ALARM1 FOR 11:01:00 & to alarm when secs match (1/min).
        ' This requires A1M1=0 and A1M2=A1M3=A1M4=1
        ' (A1xxx + $80 or A1xxx + 128d sets bit 7 as A1Mx = 1)
        A1hr   = %10010001  '$11 + $80 = %10010001, for A1M3 = 1
                            'Bit6 must be 0 for 24 hour clock
        A1MINs = %10000001  '$501 + $80 = %10000001, for A1M2 = 1
        A1sec  = $00        '$00 = %00000000, for A1M1 = 0
        A1day  = %10000111  '$07 + $80 = $10000111, for A1M4 = 1
                            'DY/_DT Bit6 = 0 for using Day of month alarm
    ' Per MAXIM TechSupport, reset control register for desired Alarm
    ' after setting alarms.
        I2CWrite SDA, SCL, RTCdevice, ContReg,[%00000101]
        PAUSE 20
    'Set the main Time
        I2CWrite SDA, SCL, RTCdevice, SecReg,[sec,MINs,hr,day,date,mon,yr]
        Pause 20
    'Set the Alarm1 Time
        I2CWrite SDA, SCL, RTCdevice, Alm1sec,[A1sec,A1MINs,A1hr,A1day]
        PAUSE 20
    ' Clear STATUS and set CONTROL registers
        I2CWrite SDA, SCL, RTCdevice, StatusReg,[$00] ' Clear STATUS register
        PAUSE 20
                                    ' Starts the oscillator,
                                    ' enables INTA interrupt from A1F.
                                    ' WORKS as intended!!
        Pause 20
        ' If the user program ends by getting to the last statement of the
        ' program at an END instruction, the MCU will SLEEP and await a wakeup.
    Feb 2005
    a 12x12 led matrix sequenced row by row needs to be turned on at least 70 times per second, so the loop needs to run 70 times 12 per second, that translates to 1.2ms per row, if I read the DS1307 at this speed Im sure I'll choke it.
    jellis, thanks for the offer, my email is pablou at gmail
    I'll recheck Darrel interrupts, no matter what I do I always peek at his work...
    thanks guys!
    Mar 2009
    Colorado
    Yes, you are probably correct that in your case using interrupts from the DS1307 isn't the way to go. It takes a 10 millisec PAUSE after each I2CREAD statement to read the clock time from the DS1307, so it would be too slow for your requirement.
    DT's Instant interrupts are still worth studying and using though in any of your applications as opposed to any of the PBPro interrupt approaches. I highly recommend them. Go here to download the files and to learn how to use them: http://darreltaylor.com/DT_INTS-18/home.html
    Not correct. Some I2C devices require a PAUSE after a WRITE statement, but READs are performed usually at max speed. The DS1307 certainly does NOT require any pauses for READing.
    There are many ways of accomplishing this without going into interrupts. Here's two...
    Software route: At the end of every row scan simply bump a BYTE Counter. When the Counter rotates through Zero (just over three times a second if you are scanning rows every 1.2ms), then do your I2CREAD of the DS1307. You'll be updating your time about three times a second.
    Hardware Assisted Route: The DS1307 has a pin which can give you a pulse every Second. Several pins on PortB have the facility to set a FLAG in a Register when the state of the pin changes. Simply check the Flag at the end of a scan and do a DS1307 READ when the Flag pops up.
    Apr 2007
    Pennsylvania, USA
    I like this! I have not used the DS1307 yet, and usually I would increment a counter like your other suggestion, but I will keep this in mind in the future. Thanks, Melanie.
    Shawn
    Feb 2005
    Thanks for your replies Melanie, one question, do you know how long it takes (in milliseconds) for the DS1307 to be read into a picbasic variable?
