only two
Results 1 to 12 of 12
Thread: only two
    May 2007
    The solution in the thread you linked to looks like it can only supply a small current to the slave (I'm guessing in the order of less than a few mA) - correct me if I am wrong. If the slave has to drive some outputs (say a motor or a lamp), do you know of a way that will allow the slave to drive a load of say 1A or more?
    Do a search for DCC. There was some talk about this a while back. Someone was doing a similar app with truck and trailer wiring, but I can not find it now.
    May 2007
    Thanks, Dave. I'm familiar with the workings of Digital Command & Control - checking to see if there is anything else out there.
    Mentor, Ohio
    Smile
    Hi rmteo,
    The request was for communications between 2 PICs over 2 wires. Not to supply current to drive a motor or lamp remotely. If you want that then you could control a remote power source or should consider something along the lines of X-10. There you can run a 12/2 or 14/2 110VAC cable and use the X-10 commands to turn lights or motors on and off without the use of PICs. I am in the alarm business. We have several alarm device manufacturers that have devices that have both power and communication over two wires but none of the devices actually draw more than a few ma's of current. The other option is RF controlled devices.
    BobK
    Sep 2005
    Campbell, CA
    You need to use a drive using a voltage regulator. I believe Melanie has posted a method. Look for that.
    Charles Linquist
    May 2007
    Quote Originally Posted by BobK View Post
    Hi rmteo,
    BobK
    Thanks. As Dave mentioned and I replied, DCC does it and I am familiar with the technique.
    Sep 2005
    delhi
    Default Dear all
    Thanx for the support got from diffrent sources i have to send data only so i need only very small curent. But still i need more illumination on my quirry to start my R&D work but still this is highly appreciable.
    Feb 2005
    Kolkata-India
    Default More than 1 pic
    Dear All,
    I know to some extent the solution Pramod is looking for. He needs a multi-master multi-slave RS485 multi-drop network of <b>sensors</b> wired over a distance of more than 1500 meters. The total number of sensors could be upto 255. More of like a CAN.
    PS. Dave were you mentioning this thread : http://www.picbasic.co.uk/forum/showthread.php?t=9406
    Sougata
